So is Dave gonna need 1" spacers in order for the wheels not to rub, or more than that?
Mustang rims and Eibach spacers install
Originally posted by Blaze86VicCould you provide a link or something? I'm interested in the diameter or our hubs.
Eibach engineers, manufactures, and sells the highest quality performance aftermarket suspension products in the world.
It cost me a whopping 20 bucks to have the insides of the front ones trimmed on a lathe, so I wasn't too concerned.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Originally posted by 88VicWhat size are those SN95 rims? They look great on the TC.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Originally posted by OVERKILLThe 90.4.30.005.3, are listed as having a 70.5mm hub centre. The rears fit perfectly. I found the front hubs were too "long" to use them correctly in stock form, the "lip" that is on them, catches on the hub. I took them into the local machine shop and they removed a few thou off of them, basically eliminating the lip and so they would slide up the hub and seat like they were supposed to. I did use four of the same on all for wheels. There is no specific listing for Crown Victoria/GM/TC on their site, so the ones I bought were for a 94 Mustang.
That was one of the problems that I had with the 2003 Cobra rims that I was originally going to install on my ma's CV. I wasn't too sure about sending them out to a shop to have the center bores shaved. I sorta like the 94 Mustang rims, but I like your idea of putting the Cobra R rims on for the summer better. If you don't have pics of the Cobra Rs, try and get some, I'd like to see that.
Originally posted by packmanThat was one of the problems that I had with the 2003 Cobra rims that I was originally going to install on my ma's CV. I wasn't too sure about sending them out to a shop to have the center bores shaved. I sorta like the 94 Mustang rims, but I like your idea of putting the Cobra R rims on for the summer better. If you don't have pics of the Cobra Rs, try and get some, I'd like to see that.
Packman1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
For a 9" LOL, 235 wouldn't even begin to fill in. 255/45 would be idle with most tires. 265/45 or 265/40 would be perfect but no one makes a 265 tire.
Go to TireRack.com, when ever you look at a tire go to the spec section on the tires. If will tell you the rid width range for each tire. You want to be in the middle of the range, or equal to that "measure rim width" but anywhere in the range is good according to the tire manufacturer.
As for the rubbing depends on your setup. You have a 30mm spacer using a 27mm offset wheel. So the wheels are going to be a little bit on the outside, but not much. A test fit will tell the tail.Last edited by Blaze86Vic; 03-21-2007, 02:10 AM.
Originally posted by Blaze86VicFor a 9" LOL, 235 wouldn't even begin to fill in. 255/45 would be idle with most tires. 265/45 or 265/40 would be perfect but no one makes a 265 tire.
As for the rubbing depends on your setup. You have a 30mm spacer using a 27mm offset wheel. So the wheels are going to be a little bit on the outside, but not much. A test fit will tell the tail.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
They are 816 revs/mile as opposed to 776 for the stockers, which isn't a huge deviation..... shouldn't make much of a difference on the speedo............ If they had a 45 instead of a 40, it would be perfect.........1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Yeah, the front end is a question on those. A question I myself will be dealing with soon. I would suggest 255/45. They look proper on a panther. Plus 285 is going to have a lot of flex in the front since you are at the lower limit of it's wheel width range. If you want to see pics of 255s on a panther, my rear tires a 255.
255/50/17 is the ideal size. Same diameter as the stock 15's. Nice and wide. made for 9" wheels. Also the stock size on Impala SS's. Haha!
I'm running BFG Traction T/A KDWS, there are much less expensive tires in that size though.
I'll be running 275/40/17's this weekend on my cobra wheels.Builder/Owner of Badass Panther Wagons
Thank you!1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
