If you are going EFI, don't get 351w, it won't fit with EFI just carb. (someone probably said that already, but I didn't read everyone's post). Unsure if you want carbed or efi.
'85 crown vic full rebuild
Originally posted by 88VicGot those two mixed up, it's 302=5.0 and 351=5.8
A 351 will fit in your car with no trouble, since some police models came with a 351. The 351 doesn't have much more power than the 302 and is heavier. If you want to get the most out of a 351, replace the intake and carb for a 4bbl intake and carb, port the heads, performance cam, electric fan, 2.5" true dual exhaust. Those mods will really wake up that engine, and shouldn't be too difficult to do, provided you have the tools and a shop manual. If you need anymore info, don't hesitate to ask, we all want to help you out. And by the way, welcome to GMN.
Thanks, got it backwords1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Rochester, MN or Rochester, NY?
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Hehehe...Buffalo's in MN too.
I've been to Rochester, and through Buffalo to Niagra Falls before, but Rochester is like 6 hours from here and my friend who I used to visit up there moved.86 Lincoln Town Car (Galactica).
Southern NJ, like 45 mins south of Philly.86 Lincoln Town Car (Galactica).
Originally posted by hazardchild69 View Postyea, i'm in NY, what part of buffalo are you from?, my gf's in the Kenmore/ Tonowanda area, we go to the lancaster raceway park on tuesdays every summer with an 85 trans am1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
ok so update on the situation, i figured out the squealing was not any of the pulleys, i sprayed everything down with rust penetrator and lubricant and the engine was running fine for a couple minutes, then the squealing started back up but the engine didnt stall out so i checked under the hood to see where it was coming from and its coming from the back left hand corner of the engine compartment, theres a decent about of smoke coming from it.. i've been looking for an engine diagram but havent been able to find one yet, any ideas?
Originally posted by hazardchild69 View Postok so update on the situation, i figured out the squealing was not any of the pulleys, i sprayed everything down with rust penetrator and lubricant and the engine was running fine for a couple minutes, then the squealing started back up but the engine didnt stall out so i checked under the hood to see where it was coming from and its coming from the back left hand corner of the engine compartment, theres a decent about of smoke coming from it.. i've been looking for an engine diagram but havent been able to find one yet, any ideas?
Left=Driver side Right=Pass. side1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
so.. i figured out it is the ac compressor that is taking a shit... still not sure what that part in the back is... looks like the rest of the ac system to me?
if i was to pull out the ac compressor etc. would i need to change anything? or can i just pull the belt off and remove the compressor?
