Results 1 to 9 of 9
Thread: {CARB-SWAP}Ok I grounded my duraspark case...
    Fack da Hulk Hogan! Grand Marquis GT's Avatar
    Nov 1982
    Hamilton, AL/Little Rock AFB, AR
    19,465
    Default {CARB-SWAP}Ok I grounded my duraspark case...
    But yet, still nothing...Still hesitates a under light acceleration...
    The box is still a little warm (I didnt drive it far, just to get it up to operating temp) Not smoking hot like it was the other day.... The coil is still cool as a cucumber, and it is mounted in stock location. wtf???
    Im prob going to get a duraspark coil, and see if that solves the issue I am having. If not, I will continue to speculate.
    The saga continues....
    Quote Originally Posted by sniper308 View Post
    Everybody have some of crazy the difference is that some have a little less and some have a little more, I have a little less combined with some of eccentric. :heyhey:
    ATT, SNIPER 308. " YOU HAVE TO BE MY EYES " Tomb Raider.
    Quote Originally Posted by DuceAnAHalf View Post
    this.
    if your letting your girlfriend run your life like that, congratulations your a bitch. grab my pocket, i just bought you for two packs of cigarettes.
    Locked and Loaded, ready for the rebellion. RugerP97DC's Avatar
    Nov 1972
    Panama City Beach, FL
    11,552
    2008 Mercury Grand Marquis GS Bone Stock
    The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
    central VA
    11,981
    yeah that coil might draw too much juice... time for teh canister!
    Wisconsin
    4,185
    Slight hesitation is not your coil.
    You have a tuning issue. If your base timing is set and you have no vacuum leaks then you need to tune your carb.
    Prineville, Oregon
    21,579
    I agree on teh timing and vac leak thing.
    The carb comes from the factory pre-tuned. I stuck mine on, and it runs great, no tweaking required. His carb came from teh same place mine did. It shouldn't make a difference.
    Tom-if you decide to go with a canister coil, make sure it has built in ballast resistor, so you can forgo the external resistor or resistor wire. Less of a pain in the ass.
    Cheese Nazi phayzer5's Avatar
    Dunnellon/Gainesville, FL
    3,462
    This will piss you off Tom, but after I got home from my speedy ride home tonight, my vacuum cannister had more heat to it than my duraspark box the only ground it has is through the dist.
    Like I said before, I run a MSD TFI coil without a ballast resistor. If any coil draws too much juice, it oughtta be mine
    I think if you get the fuel pressure issue fixed you'll be fine.
    '97 GMQ, 208k and counting
    '74 F100 Explorer, 351M-powered
    Nov 1982
    19,465
    Will a spiked fuel pressure gauge cause a smokin' hot duraspark box?
    I think not.
    this.
    look at it...pelican fly!...come on PELICAN!!! marquisman's Avatar
    innisfil, ontario, canada
    8,977
    this might be so...i was told not to use a high out put coil cuz it might fry the duraspark module.
    1980 lincoln mark VI givenchy 2-door 351W- SOLD
    1981 mercury marquis brougham 2-door 302 special blend(GMGT)- summer toy
    1985 mercury grandmarquis LS colony park 351W- winter DD/back up
    1997 lincoln town car cartier 4.6L- current summer DD
    http://www.cardomain.com/id/marquisman
    3,462
    :guns: my swap has been fine with an MSD tfl coil
