{CARB-SWAP}Ok I grounded my duraspark case...
    But yet, still nothing...Still hesitates a under light acceleration...
    The box is still a little warm (I didnt drive it far, just to get it up to operating temp) Not smoking hot like it was the other day.... The coil is still cool as a cucumber, and it is mounted in stock location. wtf???
    Im prob going to get a duraspark coil, and see if that solves the issue I am having. If not, I will continue to speculate.
    The saga continues....
    2008 Mercury Grand Marquis GS Bone Stock
    The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
      yeah that coil might draw too much juice... time for teh canister!
        Slight hesitation is not your coil.
        You have a tuning issue. If your base timing is set and you have no vacuum leaks then you need to tune your carb.
          I agree on teh timing and vac leak thing.
          The carb comes from the factory pre-tuned. I stuck mine on, and it runs great, no tweaking required. His carb came from teh same place mine did. It shouldn't make a difference.
          Tom-if you decide to go with a canister coil, make sure it has built in ballast resistor, so you can forgo the external resistor or resistor wire. Less of a pain in the ass.
            This will piss you off Tom, but after I got home from my speedy ride home tonight, my vacuum cannister had more heat to it than my duraspark box the only ground it has is through the dist.
            Like I said before, I run a MSD TFI coil without a ballast resistor. If any coil draws too much juice, it oughtta be mine
            I think if you get the fuel pressure issue fixed you'll be fine.
            '80 Town Coupé
              Will a spiked fuel pressure gauge cause a smokin' hot duraspark box?
              I think not.
                this might be so...i was told not to use a high out put coil cuz it might fry the duraspark module.
                  :guns: my swap has been fine with an MSD tfl coil
                  '80 Town Coupé
