becuase they are good in so many ways.
first things first, 12 volts doesnt sound like much but if you dont know what you are doing, step away from the wire strippers!
I'll tell you how i installed and wired mine, no warranties expressed or implied!
I used my cig lighter wiring for my power source for a relay that is activated by the car radio Key-On feed.
There is a nice plate of handy ground tabs behind the ashtray area... use em!
The ashtray has a light... I snipped the socket off and use the blue/red wire for gauge illumination and the the black wire (ground) as the ground for the relay.
Now!
electric gauges all need KO power and ground, illumination, and a line going to thier sensor(except volts - you'd be done already!)
for basic electronics, go here:
http://www.bcae1.com/
Now!
