Results 1 to 10 of 10
Thread: HELP! engine coolant temp sensor
    Member Chris84's Avatar
    Mar 2007
    Rosenheim, near Munich, Germany
    130
    Default HELP! engine coolant temp sensor
    some idiot who owned my car before just cut of the cables from the ECT sensor, to install a black cable for a extra temperature gauge... thats great
    so the car always get the wrong informations... no info...
    my question is, wich colors has the original wires to the sensor and what should i do now??
    the car is a 89 CV Wagon 5.0 liters, all standard
    thanks
    chris
    Jan 2007
    Westmont, New Jersey
    9,188
    My car has black and green wires. But mine's an '86, and yours is an '89. Good luck.
    Vicky
    Currently Undergoing A Skippyville Beauty Makeover! Too Much Stuff To List
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar (Courtesy of Lincolnmania, Gadget73 and SVT98t), Electric Cooling Fan, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, HPP wheels, Working A/C, more mods to come soon!
    Mar 2007
    130
    hmm, iīve got here a red-white cable.... and thats it... no signal return... thats strange...
    the sensor doesnīt look like the original one... no cap, no round contakts... nothing but 2 thin and flat contacts for cable shoes...
    is it possible that the sensor works without a signal return line... just with the mass?
    24,850
    You sure they cut the ECT and not just the temperature sensor for the 'engine' idiot light? The ECT will be located in the pipe fitting where the hose for the heater core connects. It has 2 wires in a plastic connector plug, but I don't know what color offhand. The idiot light sender is a single wire unit, usually with a push-on connector or sometimes uses a small nut. It is located on the lower intake manifold itself. Can you grab a pic of what you're looking at?
    Mar 2007
    130
    yes its the ECT, not the "idiot lamp" sensor... but today i fixed it... i found the cables somewhere under the hood
    now the engine works fine
    Mar 2007
    130
    humm...
    the sensor seems to be dead...
    since i plugged it on, the engine "pumps" the idle, when it gets started...
    perhaps im looking for some new sensors
    Tremont PA.
    15,275
    you can test your coolant temp sensor with an ohmeter.......directions and a chart can be found at www.fordfuelinjection.com
    Mar 2007
    130
    oh, thanks!
    this year iīm plannig to have a trip to the states... perhaps, i can visit some guys from the forum. if my girlfriend isnīt to bored
    JumboFriendly
    Guest
    Sounds like you need to attend Scottfest 2007!
    Mar 2007
    130
    humm...
    unfortunately scottfest is not in august, when iīm in the states.... ;(
    i donīt get my holydays before the end of july... because we had "a lot of work to do"
