You might be surprised. A good tune on an engine even as mild as that could get you 20-30hp. Maybe even more than that if it's running sub par because it's deviating from what the ECU wants.
Does this sound like a stock HO cam?
Originally posted by Blaze86Vic View PostYou might be surprised. A good tune on an engine even as mild as that could get you 20-30hp. Maybe even more than that if it's running sub par because it's deviating from what the ECU wants.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Quick question. Does the b cam have a rougher idle than that? Im also running a mystery ho cam and my seems to idle a tad rough than that and Im pullin around 14" of vaccuum with mine. I plan on measuring the lift tommorrow but Id like opinions.1989 Grand Marquis LS
Originally posted by Southern_Pride View PostQuick question. Does the b cam have a rougher idle than that? Im also running a mystery ho cam and my seems to idle a tad rough than that and Im pullin around 14" of vaccuum with mine. I plan on measuring the lift tommorrow but Id like opinions.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Originally posted by OVERKILL View PostThe "B" apparently has a pretty distinct idle..........
Edit: yours actually sounds a lot like a B-series cam, check out this vid for reference. http://videos.streetfire.net/search/...6c8cea5d51.htmLast edited by 88MercWagon; 04-29-2007, 04:45 AM.Nick
88 Colony Park LS
G-pa's old car, but he's cruisin around heaven in his 69 wagon now
Future plans:Semi HO conversion, or Explorer motor swap, shift kit, PI springs and sway bars, KYB-GR2 shocks
The B has a little more duration and a little less lift than the E. I dunno what it is, but I really don't think it is stock. But yet after listening to some B- and E-cams, it doesn't sound quite as bumpy as those. If I had to guess, I'd say E.1990 Country Squire - weekend cruiser, next project
I measured mine out today. It is a B cam. It does have different idle than the E for sure. The b does have less lift and more duration than the e.1989 Grand Marquis LS
I have no idea what mine is and I'm not going to bother tearing into it just to find out1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
All you need to do is take off the valve cover man. Get a venier caliper and measure valve closed and valve full open and the pushrod. Multiply by the rocker arm ratio.1989 Grand Marquis LS
Originally posted by Southern_Pride View PostAll you need to do is take off the valve cover man. Get a venier caliper and measure valve closed and valve full open and the pushrod. Multiply by the rocker arm ratio.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Oh. Well if you get time thats the easy way to do it.1989 Grand Marquis LS
here's all the Ford Racing 5.0L cams...just for reference
http://www.jegs.com/webapp/wcs/store...48353_-1_10707sigpic
