Slicktop Conversion in Progress :)
This is a sticky topic.
    Finally started the slicktop conversion on the '82. Got started last Wednesday, took about five hours to get the top peeled. Thursday I removed glue, and continued that today.
    This is why the conversion is taking place - a cracked vinyl top.
    After taking tons of trim out along the headliner, and also the package tray and rear seat, the headliner comes down. Laying the seats back, four door cars can take it out through the rear doors. Two door cars come out the passenger door.
    After taking tons of trim out along the headliner, and also the package tray and rear seat, the headliner comes down. Four door cars can take it out through the rear doors. Two door cars come out the passenger door.
    A pic of the insulation and stuff that adds weight to your car.
    The top peels off.
    Some of the green glue came off with the top (pray yours does as well).
    What is underneath the top.
    Another shot of what was left after the roof peeled off. Luckily, no rust!
    The semi-unfinished seam. The factory piled some seam sealer in the seam, painted the car, and then took a "cheese grater" to kind of smooth out the seam.
    Most of the glue is now removed. The seam sealer is going to be ground out and replaced. The rest of the glue will come when the DA sander comes out.
    Stay tuned.
    Awesome, keep up the good work!
    This will def be a sticky when done
      if the glue is being tough, you can soften the glue and make it separate easier if you use (ideally) a steamer of some sorts, or a heat gun
        Nice job! should look great when its finished.
          awesome!!
            I was thinking heat might help, so before I peeled the top I let the car sit in the sun all day. Lots of it came off with the top, so I;m thinking the sun treatment helped. I've got most of it off now by treating it with Goo Gone and scraping with a putty knife.
              Yeah get that old shit out of the seam. Put some all metal or any other quality aluminum filler in the seam. Then put a light coat of polyester filler to smooth it out. Looks like a good start.
                So what color top are you replacing it with, and where are you getting the new interior headliner material
                  he is replacing it with the invisible colour top!
                    Top is going brown like the rest of the car for now. All I'm going to paint is the top. The rest of the car could use painting, but I'm trying this out to see if I like it all brown. The cut line is going to be the c-pillar trim for the vinyl top, I'm hoping to strip it and polish it. When I paint the whole car, the C-pillar trim will come off.
                    I got a quote for the headliner yesterday. He said $50 if I bring the board to him. The sunvisors need done along with the side panels in the back. I figure he'll do it all for about $100.
                    I want to start sanding, but I need some primer so I'll have something to spray down after I sand it. But payday is late for several reasons so I can't get anything yet!
                      lookin' good Tiggie!
                      well...almost.
                      I thought about goin' Slicktop on MAGNA, but...I'm not crazy about slicktop MGMs for some reason.
                      plus, since I have the "privacy" style top(it takes up part of the rear window) I would have to get my rear tints redone...
                      meh, I'll just get it replaced...less paint to clean/wax.
                      but if I had a Vic...I'd slicktop that biatch!
                        you know me, all the unpopular stuff is a plus in my book. Vinyl tops, air conditioning, power options, EFI, aluminum wheels, chrome/stainless "granny" trim, woodgrain, etc. All that stuff that everyone else removes.
                          You aren't the only one, that stuff awesome!
                            I am gonna get my full top replaced in a year or so Hopefully some money for some new paint. White or pearl white vic with a shade of red for the top. Then I can keep my red interior :p
                              ugh what a pain in the ass the vynl top removal was for me.
                              end result tho is the best. hope yors works out like mine did!
                              BTW interesting note on the seam sealer.
                              Ford decided instead to make a pre-cut strip of foam that goes in place of the seam on the later cars
                              LTD is still here
