Results 1 to 6 of 6
Thread: 1994 Crown Victoria Window Motor removal.
    Jan 2007
    Westmont, New Jersey
    10,110
    Default 1994 Crown Victoria Window Motor removal.
    Hi Issues with my mom's car now too lol. The driverside rear window motor, and the passenger front motor. What's involved in removing these window motors. Also, what's the set up on these windows? I hear the motors working but the the windows don't move. Is the setup like what my '86 has? Or is it different. I intend to get this done and fast. Thanks in advance.
    John
    Vicky
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar, GT40 Intakes With Remanufactured GT40P Heads, Contour Cooling Fans, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, Working A/C, Big Front Brake Swap, more mods to come soon!
    Cheese Nazi phayzer5's Avatar
    Gainesville, FL
    3,723
    I've got a buddy with a 96 gmq that needs his rear windows fixed so I'd like to know too. If it's close to the box window motor bushing replacement experience then I'll be fine
    '80 Town Coupé
    central VA
    12,765
    its the same - i think you might even have holes drilled for you already
    35,324
    Not sure if the Vic is the same as Towncar, but this is how you do 90s TC window motors
    http://www.lincolnsonline.com/tech/00198.html
    Looks to be basically the same as a box provided the regulator itself isn't broken
    This is the process for the regulator (the cable setup)
    http://www.lincolnsonline.com/tech/00011.html
    Jan 2007
    10,110
    I think he said they heard snapping noises. So I guess the regulator needs to be replaced
    Vicky
    Blue
    Mods So Far:
    Jan 2007
    10,110
    Well, my dad and I got the parts yesterday, and we attempted to do the windows at my uncle's house. The regulators were pretty big. The door panels were way easier to get off than the ones in the past. They just get unscrewed, and then you pull them up, and then away. The regulators were easy to get out. Like the directions said, you had to put wood between the glass and the door frame, when you're popping out the rivits. It turned out to be the easy part lol. For we had to remove the glass. Boy oh boy. The regulator at the top, the studs wouldn't clear the holes because of the glass. So we had to remove the glass. We also (on the front) had to remove the side view mirror. Once that was done, we put in the new regulator, bolted it up, and also rivited it up. Since we had access to a rivit tool and it was way easier and more trusting than using bolts. Then I put the old motor in and ran up the torx head screws (Size 30 for you guys who might have to work on them too). The one in the back was a little easier. Did the same thing basically, then at the end, I put the motor in, it was a little harder because there wasn't much room connecting it to the regulator. Then I got my arm stuck inside the door lol. When that was done, I put the door panels and water guard on the doors and all that stuff.
    I couldn't have done it alone. And in my opinion, the job went faster with more people. My dad popped the rivits, removed the side view mirror, and worked on getting the glass out and in, and the regulator too. My uncle helped with the glass and took it out and put it in. He also got some of the window glass washers to lock in the glass. I removed the window motors, rivited in the new rivits, got the other glass washers to lock, reinstalled the motors and put the panels and everything else on. All in all, it wasn't that hard.
    Vicky
    Blue
    Mods So Far:
