wheels are a 2 part assembly... center part is aluminum and outer is steel rim. stamped on them it says Made in USA 1983 i think
Jelybean's Ford Crown Victoria
MORE PICS OF AF
picture of blocked up EGR spacer
close up of blocked up EGR passage
picture of dirty lower intake
pictures of it back together
dont worry about the dirty lower intake, ended up using a wire brush that looked like a large toothbrush to clean it and than used B12 carb cleaner to clear it out. after it was together, started it up and blew the crap out. it left a nice black spot where tailpipe blows out. the car has had an injector cleaning done before which includes stuff in the intake, dont think i will have that done again. any rate, later down the road will have the EGR spacer bored out and have a modified throttlebody to accomodate the intake.RIP DENNIS BARTLETT 1-13-2009
here is a pic of her H.O intake and the H.O. intake i am putting on my Grand Marq. definately need to get the EGR spacer bored out and get the HO throttle body i have modified to see some difference. i can hear a difference though. tomorrow it will be more work on the cars. i think it turned out good considering how dirty the intake ports were.
very nice.....needs the bored egr spacer and 60mm throttle body now.....if you mail me your ho throttle body and a stock throttle body i can fix em up for u mang
Originally posted by 87_crown_vic View Postwheels are a 2 part assembly... center part is aluminum and outer is steel rim. stamped on them it says Made in USA 1983 i think
But.
Are you fucking crazy wanting a 2 pice rim??!?!?!!!??!!!
I ask this soly due to they can kill you very quick
I knew one man lost his head due to a two pice rim. I know another man ( Which is smart ) And he had two blow off on him, However he had them turned in. ( Was on dual wheels.)
Just a thought. Other then that.
COOL.
D.K.People should not be afraid of their governments. Governments should be afraid of their people.
I took the wheels in and had the checked out , they said they will be fine to put the on AF, the were worried about getting the clean enough for the tires to seal on the wheels.. had to order washers for them.. hope to have the wheels on soonRIP DENNIS BARTLETT 1-13-2009
