The 93 GM "Tank of Justice II" (TOJ2)
    Yes.
    Yes it will.
    And burn copious amounts of oil in the process.
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      Originally posted by SVT98t View Post
      Yes.
      Yes it will.
      Any engine worth its weight burns oil without forgiveness nor shame.
        That's why I use cheapo Walmart oil, gonna spend as little as possible while it's burning and/or leaking oil somewhere. I fill up more than enough for a complete oil change just trying to keep it filled for a couple months.
          +1 walmart oil... though I do buy castrol synthetic from walmart ($10 discount compared to the auto-parts stores) for the vic.
            Ok, so the Tank is running a bit ragged right now. Not always firing on all cylinders, but it gets the job done.
            I did haul 486 lbs of scrap to the yard. In the trunk. Like a boss.
            Also, swapped out the steel front bumper for an aluminum one. Dropped 6.2 lbs off and the running total is 113 lbs dropped.
            Getting there.
              Say hello to Teksid block.
              Cleaned, blasted, ready for powder:
              Haha!!
                Don't you have a complete PI motor for this already ?
                  I do.
                    '79 Continental Town Car
                    '90 Crown Victoria LTD
                    '94 Crown Victoria
                      I've hauled a 200# or there abouts... (whatever a healthrider 600hrc weighs in at) in the trunk of the 88 making the deck lid act like a giant wing over 50mph. Was interesting feeling the car try to lift the nose at 60 mph. Care barely squatted an inch with that load. I bet the tank had a good squat going with near 500# in the trunk.
                        The front was coming up a bit.
                        But I only had to drive about 2 miles.
                          Ok, so I had a belt shift in the right front tire.
                          Poop.
                          I was hoping that it would make it a little while longer before going.
                          That's ok. I'll get it aligned the week after next, and then throw the snow tires on it until spring. That's when I'll "spring" for 4 new summer tires.
                          And the exhaust needs to be welded up.
                          Soon enough. I hope.
                            How's the blue cloud of smoke treating you?
                            Must be nice to be able to drive down the road and have such a comfortable ride that, your car puts you to sleep.
                              Puts you to sleep.
                              FOREVER.
                              Looking like next week for the tires, alignment, exhaust fix, and "inspection".
                                Oh, so that belt shift wasn't a belt shift.
                                The adapter came loose and two studs broke off.
                                So I ordered a new hub because, let's face it, I could use a new one.
                                So just awaiting it's arrival!
