and I was thinking of putting something newer on the 2.6 ....the 2.8 is getting swapped out for something that can rev a lil hire and take more punishment...3.8 out of a newer mustang.
Dirt cheap and super simple electronic ignition
Originally posted by 1987cp View PostI don't know, that's getting close to as expensive as an MSD box! Seems the main advantage would be not having a bulky external module. Wouldn't the coil have to be wired just like on a points setup, as well?
I'm bringing this back from the DEAD. I happen to do a part # search for 9FO-182 and low and behold GMN popped up...
As some of you know i've had an ignition problem for YEARS that has plagued my LTD-S. The end result is that it's probably in the wiring somewhere. I had considered replacing the wiring in the entire system...but thats a lot of work and theres a SMALL chance it's not the problem. Anyway im not here to solve that, please no suggestions, i've literally heard and tried everything.
I ordered that system tonight, the 9FO-182 petronix system. Its so incredibly simple i couldn't believe it.
The thing I would like to know ahead of time... What wires coming from the ignition switch are "Start Hot" (with the ballast resistor for the coil) and which one is "Run Hot" for the coil, for my 82 LTD, anyone with a wiring diagram? It would be much appreciated!-Phil
Red/light green is coil power with resistor (engine running).
Brown/pink is coil power without resistor (engine cranking).
They both meet at connector 219 on left fender apron, which is gray and has eight terminals, behind the Duraspark box. After the connector, you have just red/light green to the coil.
I think for the igniter/summit conversion you want the full 12v not the reduced?1990 Country Squire - weekend cruiser, next project
Thanks Tiggie! It was a late night and i mixed up which wire has the resistor strictly by accident. That's enormously helpful, I know exactly what connector that is.
If i were keeping the stock coil I would need a full 12 volts to the "module" in the dizzy, and the same resistance wire for running, and a 12 volt wire while starting for the coil. I decided just to get a Petronix coil, so it doesn't need the ballast wire and therefore decreased voltage while running. It's happy at a full 12 volts.
Wagonman, that's good to know! I want something reliable. I'm hoping it will be at least equivalent to the 40+ year old duraspark II system design.-Phil
