Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 241 to 260 of 269
Thread: My Ma's 1986 Crown Victoria LX
  1. #241
    Nov 2006
    Dirty Jersey Yo!
    7,949
  2. #242
    Nov 2006
    Dirty Jersey Yo!
    7,949
  3. #243
    Nov 2006
    Dirty Jersey Yo!
    7,949
    I took advantage of the weather on Saturday and organized the passenger side fender a bit. I separated the ignition coil wiring from the harness as I will relocate the coil to the front of the engine. I put cable terminals on the auxillary fuse box cable and the starter solenoid cable; then I installed them on the bus bar. Cleaned up the fender nicely. When I get things a bit more finalized, I will cut the zip ties, move everything off of the fender, then I will clean and paint it. I will do the same for the driver side at some point.
ID:	53387 Click image for larger version.
  4. #244
    Nov 2006
    Dirty Jersey Yo!
    7,949
    Also relocated the oil/air separator to the driver-side frame rail. It was too close to the passenger side header where I had it.
  5. #245
    Mar 2006
    Bedford, VA
    5,630
    Much better than all that factory smog junk on the passenger side.
    1988 Crown Vic Wagon - daily
  6. #246
    Nov 2006
    Dirty Jersey Yo!
    7,949
    Unfortunately, now that the fender is exposed, I feel obligated to clean and paint it.
  7. #247
    Nov 2006
    Dirty Jersey Yo!
    7,949
    Installed pcv valve and ran the line from the pcv to the air/oil separator. Also, ran the signal wires from the MSD 6AL out into the engine compartment; leaving enough slack to locate the coil anywhere. I am going to start putting the top end together and go from there.
  8. #248
    Nov 2006
    Dirty Jersey Yo!
    7,949
    So much can change in a short period of time. After adjusting to new routines both at home and at work; I was able to get some time with the CV. I installed the fuel rails, water temp gauge sender, and re-grounded everything. I originally was going to run fuel into the front of the rails and have it exit out the back and go to the fuel pressure regulator. But that freakin wiper motor box is at it again; being in the way and all. So I had to route the exit on the bottom port of the driver side fuel rail; and grind a little material off of the wiper box so the fuel rail would bolt onto the intake manifold. I ran a stud into the driver cylinder head and then ran a ground strap down to the engine mount stud. I figured with the aluminum heads, I would get a better ground by doing that; keeping in mind that I know very little about electrical systems. I came across a new problem which halted progress for the time being. My coolant crossover tube-assembly will not work with the new set-up. So I am scrambling to figure out how to run the engine coolant temperature sensor. Hopefully I will figure that out before the next decent weekend comes around.
  9. #249
    Sep 2008
    Whitestone, NY
    19,097
    Quote Originally Posted by packman View Post
    The 1986 only dual heater pipe tube doesnt work any longer?
  10. #250
    Nov 2006
    Dirty Jersey Yo!
    7,949
    It worked when I pulled it off of the lopo; but this engine is so much taller than the lopo, it crams my wiring and plumbing into a tighter space. If my computer doesn’t act wonky tomorrow, I will post pics. Too bad though, because I cleaned and painted that crossover quite nicely
  11. #251
    Nov 2006
    Dirty Jersey Yo!
    7,949
ID:	53806 Click image for larger version.
  12. #252
    Nov 2006
    Dirty Jersey Yo!
    7,949
    Wiper motor is coming off for the time being. This particular engine combo makes it a lot taller in the engine bay. The throttle body juts into the wiper motor. It was suggested that I retrofit a wiper motor from either an '88 - '91 box or use a Whale wiper motor. I will worry about wiper motors after I get the car running.
  13. #253
    Jan 2007
    Westmont, New Jersey
    10,362
    What setup are you running that the intake hits the wiper motor?
  14. #254
    Nov 2006
    Dirty Jersey Yo!
    7,949
    Degreased and painted the passenger side fender and a little of the firewall. If I'm feeling spry this week, I will degrease and the driver side fender after work.
ID:	53964 Click image for larger version.
  15. #255
    Nov 2006
    Dirty Jersey Yo!
    7,949
    Also installed trans cooler lines yesterday
  16. #256
    Sep 2008
    Whitestone, NY
    19,097
    You fancy.
  17. #257
    Nov 2006
    Dirty Jersey Yo!
    7,949
    It's the result of being bored at the tail end of my college years. Having watched a friend pour some money into his Chevelle for seemingly simple tasks; I resolved to learned how to do AN lines. Wish I had learned to do this stuff when I was young.
  18. #258
    Nov 2006
    Dirty Jersey Yo!
    7,949
    I'm trying to ID this vacuum tube coming out of the tree. I think this goes to the intake manifold? IIRC
  19. #259
    39,116
    looks like the main vacuum connection to the manifold.
  20. #260
    Jan 2007
    10,362
    Yup! Goes to the vacuum tree on the firewall.
