Page 9 of 16 FirstFirst ... 7891011 ... LastLast
Results 161 to 180 of 305
Thread: My Ma's 1986 Crown Victoria LX
  1. #161
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,258
    I everyone can agree to never have the title in the car.
    I know in Ca. It is a quite the game to break in cars one day. The next cruise by the house, if the car is not there, break into the house. Most of use don't have to worry about that crap. Just a word of caution.
  2. #162
    Nov 2006
    Dirty Jersey Yo!
    8,049
    In Jersey it's license, registration, and insurance. Title stays in a secure place; that you will hopefully remember when it comes time to sell.
    With that said; I removed the idler arm this past weekend. Also assembled my alternator. It was a real pain getting it back together. But it turned out alright for a 2-tone alternator.
  3. #163
    Nov 2006
    Dirty Jersey Yo!
    8,049
    Got the idler arm installed yesterday. Looking at the shape of the old one; I wonder what effect the replacement will have on the steering; probably need another alignment.
    I set myself up to grind out what's left of the battery tray. Hopefully will be able to do that sometime this week as it's a little slower at work. Then I will install the new battery tray and then the charcoal canister, since it sits right below the battery tray. Then I can start messing with vacuum lines and hoses and begin to wrap this swap up.
  4. #164
    GMN Regular Mike_Windsor's Avatar
    Oct 2008
    Red Deer, Alberta, Canada
    875
    In Ca. People break into cars to steal what is in the car, and get the registration. The bad guys then break into the owners home. Double whammy. Keep your registration/insurance inside the trunk, maybe in a holder on the trunk lid. If law enforcement wants the reg. tell them that it is in the trunk. You might have to explain why you have it in the trunk but any LE who has any city experience will know.
    I keep my insurance and registration in my wallet, since I'm the only person who ever drives my car. That way it's always on me and never left unattended in the vehicle.
  5. #165
    Nov 2006
    Dirty Jersey Yo!
    8,049
  6. #166
    Nov 2006
    Dirty Jersey Yo!
    8,049
    Cleaned up the battery tray area, ground out what little was left of the old tray (still some left and a couple of ground-down bolts), and test fitted the new universal battery tray on Saturday. Prepped and painted that area last night. I hope to install the battery tray next weekend. Then reinstall the evap/charcoal box; that mounts underneath the battery tray.
  7. #167
    Nov 2006
    Dirty Jersey Yo!
    8,049
    Installed Battery tray yesterday evening. I had to cut a small hole in the inner fender to get the tray to line up properly. Then stacked rubber spacers to mount it up to. It's pretty tight, but flexes with the plastic fender. At the least I have something to hold the battery down to.
    I ran out of fender washers; so I will install the last middle bolt sometime this week if I can get out of work early enough. I will shoot for installing the charcoal canister as well.
  8. #168
    19,325
    That looks good Jacob. Just make sure that bolt (holding the support to the tray) wont rub through your battery.
    In Phoenix, the battery trays were even rusted on these cars. lol
  9. #169
    Nov 2006
    Dirty Jersey Yo!
    8,049
    I've been looking at that since the install. I will see if I can get a rubber plug to place over the knub of the bolt. ALso need to get a rubber sheet to lay on the bottom so the battery doesn't touch and pivot on the bolt heads. In retrospect, I probably should have moved the battery to the trunk. We'll see.
  10. #170
    Nov 2006
    Dirty Jersey Yo!
    8,049
    I installed the charcoal box and got it plumbed into the gas tank line. I am working on placing the solenoid in a convenient spot to plumb into the intake.
  11. #171
    Nov 2006
    Dirty Jersey Yo!
    8,049
    Removed the eyesore of an EGR system from the passenger side fender. Discovered from all of those lines; only one goes to some cylinder in the back of the firewall. I will plumb a hose from the 3-way filter valve thingy in the center of the firewall.
  12. #172
    19,325
    Make sure to set the solenoid in the proper direction.
  13. #173
    Nov 2006
    Dirty Jersey Yo!
    8,049
    ^^^^^^^^^^ROFL I worried about that all winter! Kept thinking about how I can test it before firing the engine up. THat was 4 months of thinking it out. When I went to test fit the solenoid, I found that it had arrows on the back of the fitting portion *doh*^^^^^^^^^
    I also have a mess of wires that I will have to separate and eliminate one day. For now, I will tape over the plugs and push them aside. This is the beginning of the nitpicking part of the project that I don't really want to do. Plus, my Ranger is running kinda horrible; so my nitpicking time is limited.
  14. #174
    Nov 2006
    Dirty Jersey Yo!
    8,049
    I got very little done this weekend. I had to work on Saturday; which didn't bum me out because it rained all day. I spent yesterday catching up on chores and stuff; but I managed a half hour to install the evap box lines. I worked out how to mount the solenoid; I just have to get outside and get it done. Hope to actually have some time to work on the CV next weekend.
  15. #175
    Nov 2006
    Dirty Jersey Yo!
    8,049
    Last weekend I attempted to install the charcoal box line to the solenoid and the fitting broke. The local Pep Boys (5 miles from me) used to have a "performance section" with the fittings and other stuff, but sometime in the past year, they took those aisles out and expanded their warehouse. So I ended up mail ordering the fittings and other stuff that I needed. Installed the line last Weds. and have done nothing since. I hope to get to the junkyard and get the center console out of the Subaru for my gauges and get that going. Once all the wiring is done, I will get to the MAF swap and begin the process of installing the engine.
  16. #176
    19,325
    I am interested in seeing the console!
  17. #177
    Nov 2006
    Dirty Jersey Yo!
    8,049
    A couple weeks ago I went to the junkyard and found some items that I have been looking for. First pic is a center console (or whatever it's called) from an early 90s Subaru Forester. Going to trace the empty center section onto cardboard and cut a sheet of steel or aluminum out to fill in the space. That should have enough space to hold the gauges. I will obviously have to cut the console in half or whatever is needed to clear the front bench. Pretty sure I can make something up, but it would take too long for me to figure out.
    2nd pic is the center console and UCA from a 1994 MGM. I will go back at a later date and get the spindles, calipers, and LCA from either the 1998 or 2002 MGM that they have; whichever is cleanest. Also might attempt to grab the rear discs and backing plate off of the '94 MGM. I would take the whole rear, but I already rebuilt 1 rear, don't feel like rebuilding another. Though in all likelihood, I will have to do that if I want rear discs.
  18. #178
    Nov 2006
    Dirty Jersey Yo!
    8,049
    My 3rd photo that showed the fitment of the cardboard panel inside the center console wouldn't upload. This is what I am going to use for my gauges. I will cut a piece of aluminum for this; and hope I have the strength to bend it a little. I would like to find wallpaper with the same or similar wood grain pattern that is found inside the CV and stick it on the panel. If I don't, I will polish it and stick it on the console. Hopefully this works out; at least in the short term.
  19. #179
    Nov 2006
    Dirty Jersey Yo!
    8,049
    Mass Air swapeth begin!
  20. #180
    Nov 2006
    Dirty Jersey Yo!
    8,049
    Crap! I'm gonna void the warranty!!!
