No wonder Smog didn't work
    While I was in the area, I removed the smog crossover tube on the '88. To my surprise, the ends were stopped completely up. And the holes in the heads were too. I even pushed on them with a screwdriver, and they wouldn't budge.
    What could have caused them to get stopped up?
    yuck
      carbon buildup + oil burnoff, me thinks. At least you won't have to worry about cutting 5/8 bolts down for plugging the heads
        That's more common than you think. My wagon was the same way.
          so was mine
            lots of short distance not fully warmed up driving might also be related. Motor never gets hot enough to cook the crap out of it, so it builds and builds and then you get permaclogs.
              Yes, I think this car had lots of short trips in it's last years of the previous owner.
              Luckily the motor was pretty clean inside as far as sludge. The intake runners were black, however. I might seafoam the intake runners, but I don't want to bend a valve if some large chunk of carbon crap comes off. Anyone heard of bending valves when you Seafoam?
                Damn that was clogged.At least you won't have to worry about plugging the holes in the heads now,lol.
                Never heard of bending valves due to large carbon chunk breakoff while seafoaming,but I suppose if it was caked in there thick enough,it might be possible.
                  Originally posted by Chachi View Post
                  so was mine
                  Mine was starting to do that. I saw it when I did the engine swap. I cleaned it all out
                    Normally anything in the intake runners is just baked on oil sludge. Shouldn't be much chance of any chunks coming loose.
                      i found the only way to get the intake runners really clean is to remove the intakes and soak them in purple power (warning removes finishes) and pressure wash the crap out of them till they are clean........did the upper in 98 when i got my towny along with a tune up and vc gaskets, and the car ran so much better
