if you're swapping ECMs, I'd see about doing a Mark VII ECM and the larger injectors. Probably could use it with that cam and it would be the right firing order.
neutral safety switch does not affect running. The only thing that does is disable the starter relay when its not in park or neutral. It has some marginal tie-in with the ECM for checking codes, but the switch itself can be totally not present and it won't affect how it runs.
could be a fuel pump or ecm relay getting crappy on you and an off/on cycle gets the contacts a little better. Maybe try tapping the relays on the fender while its idling normally and see if it acts up
