1982 Ford LTD-S 351W Police Car
    How's the offset on those mopar steelies?
      So I didn’t measure the difference in offset but I will. I can tell you that the mounting area of the Dodge wheel is half an inch closer to the outer lip of the rim compared to my stock rims. So they should stick inward half an inch. The Dodge wheels backspacing is 4.75
      -Phil
        So the offset is +20mm, so if they don't look right I could always get 20, or 25mm adapter/spacers.
        Was having trouble with the sniper unit. Tune was perfect, then BAM, AFR wasn't right at all. It was fairly consistent though...Contacted support and they found a couple minor things wrong with my tune. It wasn't the problem though, ended up being nothing wrong with the sniper, but a misfire from a bad spark plug. I've always had lean spikes when cruising since installing the unit, I assumed this was just normal engine operation, they weren't (usually) extreme. Once I replaced the plug the AFR line tracked the target so smoothly... hurrah! The guy I talked to at EFIsystempro.com (where I bought the unit from) was extremely helpful
        -Phil
          Under all the electronics, its still an engine designed in the 1950s with the same problems they have always had. Interesting it would read lean though, I'd have expected un-burned fuel to spike it rich
            New Center link, pitman arm, and tie rod adjusting sleeves are in from 95-02 panther models. I had the stock box stuff before with the HPP steering box. Here are my thoughts:
            +Steering is more responsive, less input in the wheel is needed to get the vehicle to move, but it's not overly sensitive, if anything it inspires more confidence.
            +It seems to track better/in a straight line better, especially at highway speed
            +Turning radius is tighter. I should have counted lock to lock before i did it... however previously it didn't seem to want to reach the bump stops without some extra force, now it reaches them easily and as a result my turning radius is significantly tighter.
            +It may or may not handle bumps better... I'll need to drive it more, however bump steer MAY be reduced.
            All in all I highly recommend it to anyone doing the steering box upgrade. It's more cost...but it really completes the package, and makes it feel like a modern car.
            -Phil
              Appreciate the info. I'll grab all those parts once my current setup is worn. Currently just have the police spec 02 steering box with the factory box pieces tying everything together.
                Yup. Misfires would show up as a lean condition. Remember, oxygen sensors read the amount of oxygen in the exhaust stream not the fuel. Combustion uses up that oxygen. So a misfire would show greater concentration of oxygen.
                  So the center link rubs the oil pan at full lock on left turns... I clearanced the pan slightly and took a bit off the link, but it still slightly touches the pan. I can live with it, but want other people to know.
                  Still working on the wheels, but found a technique that works and got a hubcap installed on it. so far so good.
                  Did a spark plug reading at WOT, went through 8 plugs but got it where it wants to be. Went from 24.5 to 26.5 above 3000RPM at WOT. Gained some power and sounds better. Very efficient heads
                  -Phil
                    I'm interested
                      Originally posted by Arquemann View Post
                      I'm interested
                      So we made a ring that fit the inside of the hubcap, centered it perfectly on the wheel, and welded it on in four spots, this is just to help center it easier. Cut off the excess ring leaving 4 pieces. At that point it's trial and error. You have to fill the gap below the ring part with weld, until it fits snugly, and is centered properly. then a little weld on top at the right spot to make it so it can snap on. On these wheels i had to machine the lug nut holes to the right pattern...Here's a picture of a wheel with it done...it's not the best, but i can include more detailed photos if you're still interested
                      Finally got the new wheels and tires on. I think all the work paid off, smoother balance than before, handles way better, more confidence, ride doesn’t seem any harsher, maybe even better. Has more road feel
ID:	1290582Click image for larger version
ID:	1290587Click image for larger version
ID:	1290584Click image for larger version
                      -Phil
                        Kinda weird, the steelies look somewhat big on there... Even though other 17s I've seen look way smaller.
                        Looks pretty killer still, I would've maybe gone gloss black, factory style.
                        If you only get pros and no cons on the swap, I'd call that a major win!
                        What did you have to do the the lug holes? I though mopar had the 5x4,5 still, or is seating different somehow?
                          That came out nice. Worth it making the oldie caps fit the new wheels.
                            Nicely done!!! If I ever find the Merc Mountaineer centers I've been wanting; I would gladly give you my Ford centers.
                              Yeah they look more like 18's.. maybe its the center caps. I wanted the satin black so they'd blend in with the tires, making them less noticeable to anyone not looking hard enough, and i thought it would look more utilitarian.
                              For the lug holes I used a dremel with a carbide bit and carved out the hole towards the center of the hub. Ford is 114.3mm and Dodge is 115mm... so it is noticeable, but not a ton of material to remove. Since it uses acorn nuts they just goes slightly deeper than before, without bottoming out
                              Thanks Dave!
                              I appreciate it packman, always good to have extras on hand
                              -Phil
                                Steel wheels just need something in the middle, and original dog dishes work quite nicely with the rest of the car's looks.
