Exxxcellent!
tripminder
This is a sticky topic.
I have one of these in my 89 LX and the buttons are a pain to work. I have to push in and move them around to get them to work. How big a deal is it to take it apart and clean it? I can take a motor apart and put it back trogether again, but all the little wires and things like that are a no no!89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
Just use a small piece of sand paper... Its not hard at all just be careful and dont be like me and work on it on the carpet i think my last one got static discharge from the carpet or my body. :coocoo:The Best
Past and Present Any Questions...................
Update....
All functions now work.
First I installed the speed sensor, and ran the wires to it using the factory routing. I thought that this would be the easiest part of the project, but it turned out quite different. For some reason I couldn't get the end of the speedo cable into the VSS. After a couple of quick measurements with some calipers I determined that it wasn't going to happen without some modifying.
Remembering that the VSS I got from the yard came out of a later model box I looked to see what years had what VSS. The '86 carried a different part number that the later years. So I decided to just bite the bullet and buy a new VSS ($18) for an '86.
Well.. I had the same problem with the new VSS.
I ended up boring out the old VSS to 7/16" with a drill bit, and everything slid right into place.
OK.. now for the fuel imput (Pin #34).
I found a Blue/Lt. Purple wire dangling next to the ECM harness. The colors were right, but I didn't think I would be so lucky as to find a connector already set up for the tripminder. So I disconnected the ECM harness, and took a closer look.
I traced the wire back to.... you guessed it.. Pin #34! :banana:
Here's what I had after I reconnected the ECM harness...
From there on in it was simply a matter of hooking these two up to the Tripminder (Well.. 3 wires if you count the ground wire for the VSS).
I ran the wires through the grommet used for the cruise control harness, and routed everything along some existing wiring behind the dash for a factory setup.
Then it was time for a test drive.
Life is good.
-Paul
Then just add one. It shouldn't take too long.
You can even buy the correct terminal that's used in the EEC harness.
Or you can just grab one off a junker and slip in into slot 34. You'll just have to drill a hole for the wire in the cap (the light blue shroud you see in my pics).
BTW... are you sure you don't have anything in the harness for pin 34?
-Paul
Man trust me im 100%sure i have nothing in the harness for pin 34.. Also my cover on mine is yellow not blue like urs.. But yeah i will have to add that wire soon, where u get that connector from thou?The Best
http://fordfuelinjection.com/index.php?p=79
BTW... that's a great site run by a guy named Ryan who's from what I've seen from the past few years on a Bronco forum a very knowledgeable, and stand-up guy.
hats off to you pablito!!!
After first reading this I ran out to see if I had a fuel wire dangling from my ECM harness, but like Nate I did not, and I am sad
BUT! fiddling around in that area gave me an inspiration boost to clean up that fenderwell, so maybe while I have the cruise ball off I might feel brave enough to go poking into my ECM harness conector
Maybe Ill go poke around in one at the junkyard first...
Also while I was bonding with the fender well today, I popped apart one of its wire harness connectors and discovered you can remove/add pins into those too!
Now I can remove the stock oil/temp sender wires completely without having to damage them!!!
I know thats nothing special but it makes me soooo happy :coocoo:Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Makes it pretty easy to make your own harnesses with factory connectors.
Everytime I'm at a yard pulling parts I'll snip off a few connectors for future use.
-Paul
NATE WE MIGHT HAVE NEW HOPE!!!
check out this thread on that other site...
http://www.crownvic.net/ubbthreads/s...b=5&o=&fpart=1
and here is a copy of my reply:
I assumed the position under the dash, and sure enough a scoped out the 'little guy' (blue wire, purple stripe) with an empty connector, taped to a harness behind the speedo.
Likewise, I found a 3 wire connector with two wires in it, one of them green with a white stripe. these were part of a wiring harness that went through the firewall with a big fat vacuum line to the speedo ball. The harness also split off into a small black module that sits next to the ECM, which I assume is the cruise computer!
Nate: I saw the 'litte guy' from under the dash... you should see if you got him!!! maybe you just missed it when you looked at your ECM harness.
All: I think there are three trimpinder at my yard... i will soo be offering tested working tripminders with harness for say.... $30 shipped???Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
hey Pablito!!
eeemmm....
you wouldn't want to figure out how to apply trimpinder inputs to a towncar message center, part of the digi speedo, would you ???Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
