Mustang cluster conversion on the Merc
    I finally got this project mostly completed, so I thought I'd share some pics with you guys.
    The cluster is a '94-'98 style Mustang GT unit, with 150mph upper speedometer limit and 7k rpm tach upper limit with 6k rpm indicated redline. The cluster shape itself is shared amongst all '94-'04 SN95s. This cluster (-98) is electrically compatible with the panthers, using a VSS input, and even the same fuel level resistance. Wiring was a matter of moving all the pins around, splicing a few more power and grounds, and tapping my existing tach signal.
    To fit the cluster into the dash opening, it had to be hacked down and a 98-02 panther anti-slosh module was used as it has a narrower end. The face and bezel were unchanged as they are before the dash cluster mounting flanges.
    I installed one-off custom gauge overlays I had made by Scott. Some noticeable changes from the factory overlays include the speedometer layout, font, tachometer layout, indicator labels, illumination color (blue -> '98+ panther green) and normal text delete. I wanted to keep a factory-like appearance which we accomplished well.
    To trim the opening, I made a (few) customized dash bezel to taper the cluster opening to the Mustang cluster. This was the hardest part of the conversion and I still want to give it one more attempt to get it perfect. Many late nights were spent after work on this! The corners are fiberglassed over a foam core/mold, then bondo and after MUCH sanding glazing putty for final smoothing and last more sanding :P I used a 3M texturizer to duplicate the stock look and painted it semi-gloss black with two coats of matte finish to get the sheen just right.
    The new bezel trims it out nicely and I got the curvature almost dead-on this time, where as the last one had two peaks in the curve which made it just slightly off.. I'm not finished with this one either of course, I would still like to paint to match the factory Willow Green but didn't have time. In the mean time, the black is growing on me.
    I also repositioned the cluster just a tad from where I had originally mounted it, I think I will leave it right where it's at now.
    Enough rambling, the pics:
    More pictures: http://www.supermotors.net/vehicles/registry/7603/62684
    For comparison, here were the factory overlays with one of the previous customized bezels:
    -My Homepage, Panther info & FAQs-
    My Mint 96' Mercury Grand Marquis LSE -
    Modifications
    Click My Merc for more Pics!
    Wow. That's pretty sweet looking! Looks like it belongs there. Nice job mang
      Freakin' sweet!!
        Holy cow, that looks PERFECT in there! :jawdrop:
          Wow, that's incredible!!!
            Just when you think you can't do anything coller with that Merc, you go and surprise us. Great job
              dam dereck that looks stock nice work I really love your car
                Thanks Gabe, Tom, Nathan, et all
                Modifications
                  looks great man.
                    I still say I want to do this to my 99.
                      By far, the most unique aero Marq I've seen. And everything looks like it belongs on the car!
                      I love the work you do on this thing... never get rid of this car.
                        wow!
                          good job
                            looks wicked
                              very nice indeed. I had to go digging around for what the stock cluster looks like. The Mustang one does indeed look very authentic in there.
