Alright well I don't have my owners manual in this car, it's an Ex- Police car and the electrical system has been molested. now I open the fuse panel by the steering column and find all of maybe 6 fuses in it. that probably explains why my interior lights don't work and a few other features seem to not work, could someone be kind enough to scan or get me the diagram and the list of what spot controls what? Along with what size fuse goes there? It would be much apprieciated.
1988 CV Fuse Panel Diagram.
Originally posted by FastGallopingPonies View PostAlright well I don't have my owners manual in this car, it's an Ex- Police car and the electrical system has been molested. now I open the fuse panel by the steering column and find all of maybe 6 fuses in it. that probably explains why my interior lights don't work and a few other features seem to not work, could someone be kind enough to scan or get me the diagram and the list of what spot controls what? Along with what size fuse goes there? It would be much appreciated.
This is for Crown Victoria/Grand Marquis Only!! Unused spots here could be used for something the Town Car has
The #'s are the corresponding fuse spaces. The fuse panel should have numbers and arrows that shows you which space it is.
1 Stop/ Hazzard Lights. 15amp
2 Wiper/Washer; Interval Wiper/Washer. Circuit Breaker
3 (I don't have a #3).
4 Exterior Lamps; Instrument Illumination; Trailer Towing Relays; AutoLamp. 15amp
5 Turn Lamps; Backup Lamps; Trailer Circuits; Corner; Lamp Relays; Load Leveling 15amp
6 Cornering Lamps; Speed Control; A/C Clutch; Heated Backlight Control; Trunk Release; Police Circuits; Illuminated Entry; Power Window Relay (4 Door); Digital Clock; Tripminder; (It says Cornering Lamps again ). 20amp
7 Not Used.
8 Courtesy Lamps; Illuminated Entry; Tripminder; Clock; Electronic Radio, Autolamp. 15amp
9 A/C Blower; Heater; ATC 30amp
10 Passing Beam. 20amp
11 Radio; Power Antenna; Premium Sound. 15amp
12 Rear Lighters; Tailgate Window Key Switch. [Door Locks; Power Seats; Tailgate Window Switch; Rear Lighters.] 25amp or [30amp Circuit breaker]
13 Instrument Illumination. 5amp
14 Tailgate Window Instrument Panel Switch. Power Windows (2 Door). 25amp or 20amp Circuit Breaker
15 Not Used
16 Cigar Lighter. 20amp
17 Horn; Fuel Filler Door Release. 20amp
18 Warning Indicators; Seatbelt Warning; Automatic Lamps/Delayed Exit (Autolamp); Carburetor Circuits; Low Fuel Module; Dual Time Buzzer; Electronic Chimes. 10amp
That's all, I hope I helped you.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
If the interior lights don't come on when you open the doors, it's probably because it's a "dark car". That's the way mine is. If you look in the door jambs where the switches are supposed to be that turn the lights on, you'll probably find they aren't there.
Mine is a "dark car", and it does have the switches on the doors. My old '88 didn't have those switches though.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
probably the switches aren't plugged in or something.86 Lincoln Town Car (Galactica).
