Pesty's Crown
    Nice! Were you beating it when it happened?
      Yeah I was getting on it a bit still grandma shifting.
        You should make jewelry outta those chunks of tranny and then flash it to all those punks out there on the track with the gold chains and say "yeah, what?" "I betchya ain't got one of these bitch!"
          what gear where you in at the time was the clutch fully out?
            I wish i could do that.
              I was in the middle of the 1-2 shift.
                Damn. I was waiting for that to happen. Sorry to hear it.
                Sounds like time to turn your T5 into an A5:
                http://www.astroperformance.com/prod...roducts_id/207
                That website also sells single stock components in case you decide to just replace what you've broken.
                T5s are some of the simplest manual transmissions to rebuild. I doubt you'd have a problem doing it yourself. There are a couple guide videos that I've heard REALLY help out. If I can find the link to one that seems to get the most positive feedback I'll send it your way.
                  Damn $1300 and I have to build it myself I can buy a brand new one for that price.
                    Oops, forgot about this one. I knew there was a cheaper kit available.
                    http://www.astroperformance.com/prod...roducts_id/148
                    Keep in mind after buying this kit you still need to buy a rebuild kit if you're going to replace the synchros, seals and bearings. Rebuilding a T5 is something you can do in an afternoon with access to a press.
                      Damn, I also forgot to mention -
                      You may be able to save money by just buying a decent-condition T5Z, which is the T5 available through FRPP and came in the '93 Mustang Cobra. I've seen them go as cheap as $500 on corral.net, though the average for a used one is around $150 more most of the team. I see them rebuilt with under 3,000 miles on them for around $800 on the Corral fairly often.
                        Well I went to the shop that I had it dyno'd at and gave the tranny to their tranny guy. He is supposed to call me with an est.
                          Their telling me $850 for a complete rebuild. New syncro's, third gear, cluster, and other such goodies.
                            You should call D&D performance, and ask them about a rebuild. They can help point you in the right direction of making it stronger so this has less of a chance of happening again. I bought my Tremec from them. Damned good guys!
                            http://www.ddperformance.com/
                              good luck deciding what to do with that tranny. that car is freaking awesome!!!!!!!!!!!!!!!
                              2000 HPP Mods
                              15.2 @ 89.13mph-1/4 mile
                              9.73 @ 72.01mph-1/8 mile
                                Pesty, I'd definitely suggest looking into doing it yourself with stronger components. You can save a shitload of money that way, and I assure you you possess the mechanical ability to do it. The T5 is an incredibly simple transmission. I had mine apart and back together within two hours of getting it home, and you've done a lot more complicated work than I've ever done..
