So I adjusted the TV cable on mine to hold the gears out a little bit longer than how it was (I believe it was set at stock, where the adjuster block meets the grommet when the throttle is closed) and I increased the pressure a little bit.
I go back to school, and the very next day I get a call from my dad saying that the throttle is sticking open when he starts it. As soon as he pokes the gas a little bit, it unsticks, but after he shuts the motor off, it starts to stick again the next time he starts the motor. This was not happening until I readjusted the TV pressure, and it sort of seems like the TV cable was holding the butterfly valve open a little bit when the throttle was closed. Any ideas?
