Jon, that's definitely an odd behavior, as the Navistar is pretty much the diesel version of a carbed car - no electronics on that beast, tis all mechanical. You say a clutch, so that rules out the PCM for the E4OD... I'm stumped at that man, but I will ask on my diesel board cause I definitely wanna know more about it, I'll let you know whet the other folks come up with.
By the way, with that 6.2 engine, what tranny are you gonna run behind it? The AOD won't bolt up, neither will a C6. IIRC the GM diesel uses their regular bellhousing bolt pattern (unlike Ford with the diesel specific trannies), which means you can run any TH400 or TH350 you can get your hands on. Believe the 350 is dimensionally smaller than the 400, and so may be more suitable for fitting under the Townie floorpans.
