Results 1 to 18 of 18
Thread: 460 swap?
    we're all here,cuz we're not all there!!! lwoodblues's Avatar
    Apr 2008
    Sunny Florida
    6
    Default 460 swap?
    I have access to a 460 and c6 out of a late 70s pickup. What do you think of this swap in terms of ease. Anyone out there done it, or know of it being done?
    34,974
    Someone on another forum did it I believe, but I have no details. Maybe MrLTD or GMGT knows who did it.
    Wisconsin
    4,229
    It depends how easy you personally find doing a swap with custom headers, exhaust, accessory brackets, transmission mount, driveshaft, fuel system and wiring.... Not to mention potential clearance issues with hood, wiper box and heater box....
    It is a significant project which is not for the weak skilled nor light pocket book types....
    Nov 1982
    Abilene, TX
    20,353
    It is definately not a project for the inexpirienced.
    Mounts, you will have to get creative with. Sanderson makes a set of shorty headers that should work in our chassis though.
    I am actually putting together a stroker 460, i'm going to have to get creative with a welder and an assortment of factory accessory mounts.
    Oilpan, you can use a fox chassis 460 swap pan, made by Ford Racing.
    A lot of the other details will require fabrication, but I think you'd be happy with the swap once you did it. Good luck, and let us know the progress!
    1983 Grand Marquis 2Dr Sedan "GMGT"
    Lets put cough drops in out buttholes and play video games DuceAnAHalf's Avatar
    florida
    6,674
    Quote Originally Posted by Grand_Marquis_GT View Post
    i think you might need some additional hands from someone who is used to making stuff work.
    Dave84
    Guest
    A 460 truck oil pan will work as well. They are the same as a fox body 460 pan.
    bigger is better over2tonsofFun's Avatar
    Nov 2007
    Laramie, WY
    203
    There is a kit for a Big block Ford in a Panther:
    Total Performance in Michigan has it, These prices are from a few years ago so I am not sure if they are correct:
    Frame brackets------ 189.00pr
    motor mounts-------- 79.00pr
    oil pan w pick up dip stick & tube 7 quart 289.00
    Exhaust manifolds-- cast iron used 98.00pr
    Aluminum radiator 269.00
    they also can do a complete turn key.
    Tim
    84 Lincoln Town car signature, field find
    89 Lincoln town car: RIP
    Wisconsin
    4,229
    Are you sure Total Performance Even exists any more??????? That isn't exactly a kit.. Using factory manifolds is not a worthwhile performance option..... What were they using for frame brackets? They are likely using factory motor mounts as they did with the T-bird swaps.
    Nov 2007
    Laramie, WY
    203
    Yeap still around:
    Take from Yahoo yellow pages a couple minutes ago;
    Total performance
    44050 N Groesbeck Hwy, Clinton Township, MI 48036
    Phone: (586) 468-3673
    don't know what they use for parts but I know there work is first class. The owner is a former director of racing for Ford. He has a 427 SOHC powered 63 Country Squire and a matching SOHC powered drag boat. I am sure they can fab up some headers.
    Tim
    Wisconsin
    4,229
    Quote Originally Posted by over2tonsofFun View Post
    Other than Tom, you likely will not find anyone soon on the board willing to pay for custom fabbed headers.
    34,974
    this is entirely true. What do the fox 460 swap headers look like? Maybe those can be used, or if there is a BBF shorty for some application, possibly something could be worked out
    There's no welders in Heaven, they all went down to hell
    Apr 2005
    Chesterland, Ohio
    3,182
    460 fox swap headers are over $700 new, not really much savings over a custom set and I doubt they would fit... You might find a used set for cheaper tho to tinker with.
    Wisconsin
    4,229
    JBA used to make a shorty header which should work. Because of low demand, they currently do not stock it... Perhaps they could be talked into doing a few sets if there were a group purchase...
    Ford Police Motorsports trwp72's Avatar
    Longview, Texas
    3,006
    There is someone on another foreum that did this.... He used a accesory setup that is sold for 460 Mustang swaps... it basically lets you use your 302 brackets... It consists of flat plates, with holes drilled and tapped so that you just bolt on the brackets off of the 302...
    I think he bought them online... From Summit Racing...
    I think he also used the stock exaust manifolds...
    Tom...
    Pirate
    Guest
    Tim
    The Panther big-block swap kit has never existed. This has been verified by John Vermeersch himself, the owner of Total Performance, who I have spoken to on several occasions. The kit was never made, and was in reference to a Car Craft article back in the late 1980's that some idiot pieced together, without calling and asking John for verification. John had talked about it...once...and for somehow or another, that discussion developed into a complete engine swap kit, with prices and parts...and not a single kit was every produced, sold, or created. This has bugged the hell out of him for the better part of two decades, as he has received several dozen phone calls for orders, and has gotten into several screaming matches with idiots who won't take 'no' for an answer.
    This isn't meant as a slap toward anyone, this is simply to kill off that idea for swap parts, before anyone else calls the poor guy for a non-existent swap kit. At this point, you are going to have to follow the one guy here who did one, and he hardly ever posts in here...if at all. I do have Lee Senior's email address (he's the one who made the 5.0 mustang brackets to work with the 460-into-CV swap, and at last count, he was charging around $200 or more for the belt-drive kit.
    Concerning Total Performance....I have John's phone number, but the business has ceased to exist, other than some light side work of his.
    Pirate
    Guest
    The fox units don't fit. I deservedly got an ass-chewing from the guy that did one here about my mistaking the fox body set for the set that fit the box....they don't even come close...he bought a set of hooker Mustang swap headers, and they were observedly the wrong ones....I think he has a picture of them on his supermotors page, and how badly they fit.
    What this stems from, is I did test fit a 460 into a 86 box wagon...and I had three sets of headers that all fit perfectly. I had borrowed the sets from a guy who claimed that they were all Fox body swap headers, and from what I had seen at the time, they honestly looked like the swap headers I had seen at the time. However, I abandoned the project, and haven't revisited it since.
    If I ever build another panther, it will be something small-block motivated, whether it be stroked, turboed, or supercharged.
    Quote Originally Posted by trwp72 View Post
    Tom...
    This is the Lee Senior kit I am speaking about...
    The one known set of headers that fits is from Ford Powertrain Applications, out of Renton, Washington.
    Nov 2007
    Laramie, WY
    203
    Damn, Didn't know he never produced the parts. I was going off the info/price sheet I was sent a few years ago. I guess I will have to go it solo when I get my 2 door.
    Tim
    Wisconsin
    4,229
    Back in the early 90s, Chris Kauffman used to do custom bracket work and other stuff.... this part of his business fell to the wayside along with the others....... I stopped in at Kauffman's place, JBA and Monster Miata back in the early 90s when they were all having fun with custom stuff.. Monster Miata is the only place doing the same thing they did back then because they specialize in a small niche....
