HO TB swap w/ bored stock spacer
This is a sticky topic.
    H.O linkage on the left, lopo on the right. Have to grind both of them off and then swap the lopo onto the HO one, then tack it back in place.
    Difference in the throttle bodys
    Lopo linkage on HO throttle body
    Lopo EGR spacer on left, HO on the right, before boring out.
    Lopo on the left, HO on the right, after boring out.
    sigpicVic Videos Here http://www.grandmarq.net/vb/showthre...676#post243676
    Vic's Reader's Rides Page http://www.grandmarq.net/vb/showthread.php?t=16917
    Vic's Cardomain page http://www.cardomain.com/ride/2532949
    1975 Chevy C-10 Cardomain http://www.cardomain.com/ride/3371894
    Why not just drill 2 new holes? 1 for the TV bushing and another for an aftermarket throttle stud?
      Because it's easier to swap the whole linkage than to attempt to get the correct location for the stud and TV bushing. It's be pretty tought ot get the stuff centered, since you would be drilling into part of another hole...
        Not really.....
        I just lined my mustang TB lever with the lopo TB lever, marked the locations,drilled the holes and installed a Throttle Ball from the Holley Carbs TB Kit, available from jegs.
        Once the original Throttle Ball is ground off the HO TB, the TV Cable hole is the only hole that will remain in the HO TB lever. The hole for the new throttle ball is drilled to the left outer edge of the old Mustang TV cable hole, and does not even come close to connecting with the old TV cable hole. The new TV cable hole is drilled slightly to the right of were the old throttle stud was, and since the throttle stud was ground off even with the surface there was no hole left behind from it, to interfere.
        I just took my time with it, and it came out right the first time. Didn't even have to adjust my TV Cable.
          Maybe its the air tools. Makes swapping the levers a simple matter. Probably sucks doing it by hand with a file.
            Just something to mention here, the 1986 model uses a specific throttle lever to work with its one-year only TV cable. It uses a peg that the TV cable hooks to, not a hole with a bushing like other years. Drilling holes and using carb throttle linkage parts is not an option for those vehicles, the lever must be swapped over.
              yes i also plead the 86
                Took this pic of my Modified HO Throttle Body, while I had the Upper Intake off today. It has over 15K DD miles on it since I did the Mod to the TB, and it is holding up perfectly.
                I also drilled the hole for the TV Cable brass bushing so that it is a Press Fit in the TB arm, and cannot slip out.
                Maybe this pic will help someone who is thinking of modifying a HO TB to fit the Box Panther setup.
                  thats what ive been looking for thanks for the pic!!!! now i hav much better idea how its supposed to go
                    Since all the images from the first post are missing, I was hoping someone has some shots of how the modified TB looks.
                    I have both stock and Mustang throttle bodies and just need to swap the pieces over but want to see how far to cut/drill to release the throttle arm or whatever you call it.
                    Do I just have to grind until the parts come apart?
                      Just grind it down till it's flush with the lever itself. Then some gentle persuasion and it will come apart.
                        Yep. What Zach said. With the grinding it sorta gets stuck together pretty good but some prying gets it free.
                          I got them free today, now I have to get them back into one functioning piece.
                            Has anyone dyno'ed their car after the HO upper and TB swap only? I'm wondering if it's worth the effort of swapping the throttle linkage and boring out the EGR spacer if it'll only mean a barely, if at all noticeable gain in power. I need to do the intake gasket and replace all the vacuum lines so while I have it off, I'd like to know if it's worthwhile to assemble and modify the parts necessary. I'm not building a drag racer but every bit helps, if it's noticeable I'd like to tackle it when it's convenient.
                            Also do you guys have a machine shop bore out the EGR spacer? I don't have the tools or knowledge to even think of attempting that.
                              On my bone stock 91 GM, I went from a 11.53, to a 11.39 in the 1/8'th with nothing but the HO upper/TB/EGR
                              Pete proved it's about a 10hp upgrade at the wheels on the dyno.
                              It's a huge upgrade in throttle response. IMO, it's one of the first mods that should be done on a lopo
