Results 1 to 7 of 7
Thread: Crazy assed wiring....
    fixing my brokeded cam 351wcrayz's Avatar
    Sep 2007
    Salyersville
    318
    Default Crazy assed wiring....
    OK, now the wiring is freaking me out, 12pm last night the passenger side, front window decided to
    work mysteriously after 3 yrs of not working......
    The seatbelt light and chime also started working magically then said fuck it and stopped a day or two afterwards...
    So am I lookin at a total re-wire of the electrical system or what?
    Also, when I start the car at night the headlight brighten/dim with the engine.....ANY idea on that?
    P.S-Battery is new, and the alternator charges so idk....
    -Wes
    [SIGPIC][/SIGPIC]1991 Crown Vic 351w 5.8L
    Jan 2007
    Westmont, New Jersey
    9,177
    Quote Originally Posted by 351wcrayz View Post
    -Wes
    Do the lights brighten when you step on the gas? If they brighten it's fine. They all do that at idle or when at a stop, especially with the 2G alternator (don't put out good volts at idle) If those things that haven't been working are working now, I would just have to say that there are dirty connections somewhere
    Vicky
    Currently Undergoing A Skippyville Beauty Makeover! Too Much Stuff To List
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar (Courtesy of Lincolnmania, Gadget73 and SVT98t), Electric Cooling Fan, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, HPP wheels, Working A/C, more mods to come soon!
    It's my belief that my big balls should be held every night. 91waggin's Avatar
    Feb 2008
    Portland, OR
    1,516
    -Wes
    Track down the connections of the things that are being finicky. I bet ya find some loose wires or some frayed wires or some messed up plastic connectors.
    As far as the headlights go, clean your connections at the headlights and do a 3g alt upgrade.
    The wire for the seatbelt light/chime is under the driver's seat.
    --Graham
    Sep 2007
    Salyersville
    318
    well, more news on this subject.
    The girlfriend randomly pulled up on the rear driver side door handle and after 2 yrs of not working it opened......Solenoid+bad connection methinks.....
    And 86vickylx, the lights do like you said, they brighten real nice like when I hit the gas while its in PARK, but when its in drive they stay the same.....
    Thanks mangs-
    -Wes
    GMN Regular 86GmLsCoupe's Avatar
    Apr 2005
    Linden, NJ
    1,103
    I believe the window motors have a thermal lockout switch built in, when my old motor was weak and dying it would stop as it was struggling and then work again, maybe 15 mins or even a day later. On a side note, I thought since last August my driver power mirror had died, but when putting the new regulator in the other day I noticed the plug was undone, so when you get the chance check for a loose or undone plug.
    The chimes and seatbelt light are controlled through a box somewhere behind the ashtray. The plug could be loose for that. My chime speaker is dead but I hear it faintly sometimes. Theres a wire in the seatbelt plug that completes the circuit but mine had a break in it from age & use so the light would always stay on. I fixed the break but the light still stays on and oddly sometimes goes out. I just ignore it for the time being.
    For the headlights, I agree a 3g upgrade will eliminate the problem. Overall I think the wiring on these cars is pretty decent. The main issues are the 2g alt, headlight and ignition switch so keep them in mind. The only thing I haven't been able to fix yet is the seatbelt light.
    1986 Grand Marquis LS 2 Door
    Ext: Medium Shadow Blue Metallic, Int: Midnight Blue, 3.08 open, 235/70/15 Goodyear Aquatread III, Rebuilt AOD w/ Transgo Shift Kit, 3G upgrade from 95 5.0 Mustang, Walker Dual Exhaust w/ H pipe, Viper 5900ST alarm, De-smogged, Rear Civ. Sway Bar, and more.
    24,819
    The motors do have a thermal limit, and the brushes also wear out. Sometimes a good smack fixes them for a little while. I've got a rear window motor thats gone intermittent like that. Whenever it fucks up I just slam the door and it works again for a while.
    Apr 2005
    Linden, NJ
    1,103
    Yep that worked for me when the old one was dying, I'm pretty sure I remember hearing that tip from you.
