Front coil springs
    Front coil springs
    I am looking for PI front coil springs, I have looked through the stickys, and went through all then links, but cant find any the same rate as the PI springs.
    I think 925 is going to be a little to stiff, but i think the 700 lb/in will work fine.
    Where can I find 700 lb/in springs for the front of my 88?
    thanks
    Also, I have looked on NAPA, advance, and autozones websites and all of them seem to be in the 3-400 lb/in spring rate
      98 grand marquis
        good deal, thanks.
          i used a 98 PI for springs. the PI springs are gonna be a little stiffer
            Where did you find 98 PI springs?
              Also, did you cut any coils, or did you leave them the way you got them?
                i got mine from the dealer, and i just ran them stock
                nevermind, i forgot, it was rear springs that i bought
                  Rockauto shows some front heavy duty coils (5851220)with a wire diameter of .781" and that is the same as my used 1989 PI coils from the junkyard.
                    read the spring stickys
                      I did read the spring stickys But when I followed the links I coulndt find any spring rates of 700lb/in
                        Awesome, thats exactly what i awas looking for, and a decent price as well.
                        Thanks
                          89 PIs have pretty soft springs compareed to the later years. All box springs are pretty darn soft. Gonna want some 98-02 springs.
                            I got mine for a 98 at bennet auto parts. They are moog's IIRC. Cant remember the part number off hand I'll have to look it up.
                            1989 Grand Marquis LS
                              1992-2002 Police Interceptor front coils are 700lb/in, just what you want
                              p/n: D9AZ-5310-AN
                              They run a little over $100 a pop retail at the dealer. Cheaper if you order online, ie Fordparts.com or similar.
                              They may want a suspension code - give them "NN" for the front. Which translates to spring catchcode NUL, which the number above is for.
                              For just a bit more $$ you can have custom springs made to your specs - rate and ride height (from stock) however you want. Coilsprings.com is where I got mine.
                              Keep in mind, if you use worn/used coil springs they will not be as stiff or have the same ride height as brand new.
                              98 grand marquis
                              A '98 Marquis would have only 440lbs/in front coil springs. Unless it's an HPP, in which case like all '92-'02 HPPs 540lbs/in - still short of his 700lbs/in target though.
                              -My Homepage, Panther info & FAQs-
                              My Mint 96' Mercury Grand Marquis LSE -
                              Modifications
                              Click My Merc for more Pics!
