Motor oil, not antisieze. Antisieze is a nice way to fuck up the threads. Supposedly it eats the plug threads.
Oh dear The baconator is DOWN !!! HELP
Good luck getting them out next time. If you are installing plugs on a motor with aluminum heads you must use anti sieze. The plugs will actually weld themselves to the head if you dont.
As for torquing the plugs just make them nice and snug NO KUNG FU GRIP!R.I.P Linsey Nelson
'04 M75-"Chocolate Rain" - mid 13 beast
Originally posted by MeanVic84Chocolate Rain. Some stay dry and others feel the pain.
Originally posted by Grandmarchris View PostGood luck getting them out next time. If you are installing plugs on a motor with aluminum heads you must use anti sieze. The plugs will actually weld themselves to the head if you dont.
STOP TELLING PEOPLE TO DO THE WRONG THING. If you insist on doing dumbshit to your own car,Well thats ok..Its yours.Stop advising anyone else to do the same.
Woah no need to get mad..I have been told by ASE cerified mechanics to always use anti sieze when installing plugs into aluminum heads and thats what I have always did without any problems. Untill I read this...
CHANGING SPARK PLUGS
When changing spark plugs, wait until the engine has cooled to remove the plugs. This is very important with aluminum cylinder heads because it reduces the risk of damaging the threads in the cylinder heads when the plugs come out (aluminum is a much softer metal than cast iron).
MOST threads on spark plugs for engines with aluminum heads are either precoated to reduce the risk of thread damage, or the plug shell is made of a nickel alloy. If the plug shell is black or plain steel, however, you should put some antiseize to the threads, and reduce the applied torque by about 30 to 40%.
Do not use antiseize if the plug shell is nickel or has been precoated. Antiseize acts like a lubricant and may allow too much torque to be applied to the plugs, damaging the threads in the cylinder head.
Source:
http://www.aa1car.com/library/sprkplg2.htmR.I.P Linsey Nelson
