Nitrous swallowing, fire breathing Windsor Now with videos
installed the lower radiator hose today.
have main fuel line( -8) hooked up to regulator, and have unused output side of reg. capped.
need to finish tightning two ends on fuel line between filter and pump, and need to cut line and install ends to go between pump and the union on the hard line.
need a voltage regulator for the 100amp taurus alternator.
need to get my yellow top bacvk from my brothers T-bird.
need to hook up tranny cooler lines (unfortunatly the old ones are just about useless)
bought a hayden Tranny cooler today but it was missing the fittings out of the box( it uses -6 AN fittings)
i should be ready to fire it in a week or so.
looking into getting a aluminum radiator, will only cost about $175 for a 19 "X 31" race radiator from www.speedwaymotors.com
as for heads im either gonna go with the World Roush 200 heads (if i can still get them when i order) or i will go with the World Windsor Sr.
finished making up my braided stainless lines. still need to drill hole in trunk to run the line from the pump to the hard line.
refilled the differential with 2 qts. of Lucas heavy duty gear lube. Cannot install mu MN-12 diff. cover with bracket due to the sway bar, i might have to drill some new holes for the sway bay further back to clear.
so i need to install battery, fill with coolant, run tranny cooler lines, and connect one fuel line and then i should be able to fire it.
its only 10-20 minutes hovering a few hundred rpms around 2k, then there's the first few oil changes to get out of the way....then the burnout christening!! :3gears:
'80 Town Coupé
