Results 1 to 14 of 14
Thread: Lincoln won't start...
    GMN Regular
    Mar 2008
    Fredericton, N.B. Canada
    12,405
    Question Lincoln won't start...
    The Lincoln wouldn't start tonight, I figured the wet weather is to blame...The car started/ran fine earlier in the week, when it was nice and sunny!
    '79 Continental Town Car *In storage for the winter.*
    '90 Crown Victoria LTD *In storage for the winter.*
    '92 Crown Victoria Touring Sedan *Parts car.*
    '94 Crown Victoria *Daily driver.*
    Working with half my brain tied behind my back just to make it fair Nathan in MI's Avatar
    Sep 2011
    Big Rapids, MI
    7,373
    Symptoms?
    GMN Regular
    Mar 2008
    12,405
    My step-bro (mechanic in training) figures it's an ignition-related problem. We tried boosting the car and that didn't help. The battery is only about 4 months old. The spark-plugs were replaced about 2 months ago...perhaps it's a bad wire?
    Birdsboro PA.
    16,740
    got spark? fuel?
    dont leave us much to go with here
    GMN Regular
    Mar 2008
    12,405
    The engine would turn-over. The gas-tank & fuel-filter are only 3 months old. Fuel-gauge reads 3/4 full. I bought gas last week. I have no idea how old the alternator is...
    Birdsboro PA.
    16,740
    still does not answer my question
    GMN Regular
    Mar 2008
    12,405
    No spark but fuel-delivery seemed fine.
    Sep 2011
    Big Rapids, MI
    7,373
    When did it last have a new cap/rotor/plug wires?
    LumpyCheeseman
    Guest
    if the cap/rotor and wires are old, any condensation in the cap could potentially be negating the spark that is trying to jump. cap and rotor are cheap, so are wires, ifyou havent changed tehm all in a while, do it soon
    35,324
    No spark = no start. 79 is DuraSpark, which is not that weather sensitive. If you have no spark at the ignition coil, its not the cap or rotor. Its also not a bad wire. I'd be more inclined to think bad connection at the coil, bad connection between the distributor and Dspark box, or maybe a bad Dspark. You'll need to do some more diagnosis.
    1) Do you have +12v at the + side of the coil with the key on (test light is fine to check)? If yes, goto 2. If not, check your connectors at the starter relay, at the coil, and the ignition switch.as well as the ballast resistor.
    2) Do you have 12v at the + side of the coil when cranking? If yes, goto 3. If not, check the connection between the I terminal on the starter relay and the + side of the coil.
    3) If the test light is across the coil, does it blink when cranking the engine? If yes, goto 4, otherwise check the connections at the dspark box, and at the distributor.
    4) Will the coil spark to ground when cranking? If yes, goto 5, otherwise replace coil
    5) do you have spark at the spark plug end of the coil wire? If yes, the motor ought to run. If not, check/replace the igntiion wires and distributor cap/rotor.
    There's probably a much more comprehensive troubleshooting chart for the ignition system, but that ought to get you pointed in the right direction.
    35,324
    GMN Regular
    Mar 2008
    12,405
    Thanks for the suggestions guys! New cap, rotor, plug-wires & ignition-coil have been installed. The Lincoln starts & runs awesome now
    Jan 2007
    Westmont, New Jersey
    10,110
    Good to hear.
    Vicky
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar, GT40 Intakes With Remanufactured GT40P Heads, Contour Cooling Fans, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, Working A/C, Big Front Brake Swap, more mods to come soon!
    Birdsboro PA.
    16,740
    excellent
