2022 Ram 1500 4x4 5.7 Etorque, Built to Serve Edition, (Granite Crystal / Black) Past Panthers
It should have a high flowing but stealthy exhaust if you stay with the luxury theme. Something like 2.25" duals and Super Turbo mufflers would be nice, quiet when you want but mean when you step on it.
A buddy with an identical car (79 Towny, 400 engine) has a set of glass packs on his with no converters and it sounds pretty good. Doesn't sound obnoxious like I find most cars with glasspacks. Sounds nice when you step on it too.
I'd go with 2 1/2 pipe. It's 2 1/4 stock. The 400 will appreciate it. You could probably use impala tail pipes if you want. That's what I did on my Gran Torino.
if its old enough, yeah. depends on where you are really. some states dont require inspections
2010 Toyota Camry "Traveller II "
54,xxx miles. New daily driver
2001 Lincoln Town Car Signature "Leroy"
rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
114k miles. Sold to my coworker.
1998 Toyota Camry "Traveller"
Dead and sold.
I had the windows down and heard it fall off as I was driving but couldn't pull over...The busiest intersection in the city and traffic was thick. Luckily, I have a spare center cap that I bought last year from a GMN'er.
'79 Continental Town Car
'90 Crown Victoria LTD
'94 Crown Victoria
Always smells like mice urine in there... Don't worry, I was wearing goggles and a mask! I decided to remove all the carpet to see what shape the trunk floor was in. There's some minor surface rust but no holes. On the right side, there was some nasty insulation, which I removed and trashed. After cleaning up the metal a bit, I sprayed some rust converter on the bad spots. After primer, I sprayed some black paint. Ran out and so did the daylight. Hoping to finish this job by the weekend.
'94 Crown Victoria
