Page 252 of 253 FirstFirst ... 152202242250251252253 LastLast
Results 5,021 to 5,040 of 5043
Thread: My 1987 Two Door Crown Victoria AKA THE BROWN BLOB
  1. #5021
    Jan 2008
    New Jersey
    3,115
    Did you push her in the corners? How’d it do?
    -Phil
    +1982 Ford LTD-S Police Car. 351w, GT40 Heads, Edelbrock 1906 Carb, Full exhaust headers to tails. 3.27 Trac-Lok Rear. Aluminum Police Driveshaft. Speedway Springs+Bilstein Shocks, Intermediate Brakes, Baumann Shift kit.
    Sep 2008
    Whitestone, NY
    20,007
    Quote Originally Posted by Brown_Muscle View Post
    Took it out again this morning. Cant say I feel much of a difference. I also haven't pushed anything either.
    What I can say is that I still am experiencing the same wheel hop as before with the stock LCAs. I will have to dive into measuring pinion angle and utilizing the adjustable upper arms to get it within reason...if it is even out of whack. It only happens if I am putting around town in first and stop on it and stay in first till high rpms..5/6k. Under normal driving I have no problems. I also haven not tried out the line lock to see if I have this wheel hop while standing still.
  3. #5023
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,602
    Wheel hop is very abusive to your axles. Do you have a magnetic angle finder?
  4. #5024
    I post a lot...
    Dec 2011
    Yonkers NY
    4,285
    I am sure a magnetic axle finder is a real thing but my first thought was I would find them on the shelf next to the left hand smoke sifters.
    What does a magnetic axle finder do?
    Jay
  5. #5025
    Mar 2010
    Lewisville, TX
    22,171
    Magnetic ANGLE finder. You put it on the pinion part of the diff housing to to make sure that angle is the same as the angle of the transmission tailshaft.
  6. #5026
    Sep 2008
    Whitestone, NY
    20,007
    Quote Originally Posted by mitymerc View Post
    Yes. I had purchased one when I purchased the control arms in anticipation of having to set pinion angle. For now I will just avoid making axle hop happen.
  7. #5027
    I post a lot...
    Dec 2011
    Yonkers NY
    4,285
    Oh Doh! I may have to take remedial reading.
  8. #5028
    40,186
    Quote Originally Posted by jaywish View Post
    Jay
    finds magnetic axles obviously.
  9. #5029
    I post a lot...
    Dec 2011
    Yonkers NY
    4,285
    Now why didn't I think of that?
  10. #5030
    Sep 2008
    Whitestone, NY
    20,007
    Well....
    Line lock worked great.
    No wheel hop whatsoever while doing this burnout.
    Not as pressed to mess with pinion angle now. Still curious though why it will do it while rippin in first gear.
    Attached Thumbnails Attached Thumbnails IMG_3793.jpg   IMG_3791.jpg   IMG_3790.jpg
  11. #5031
    Nov 2005
    2,602
    Hey, I know where you did that!
  12. #5032
    Nov 2005
    2,602
    From a buddy that knows his shit...
    "It might not be square.
    Tires will affect it if they're trying to hook/spin/hook.
    SHOCKS?!
    Rear may be trying to "dribble" the tires."
    "Cheap street radials?
    Have to treat the car somewhat like a drag car. Plant the tires & keep weight on em"
  13. #5033
    Nov 2005
    2,602
    Also
    "If he over tightened the rear suspension Id expect it to just spin. Sounds like combo of tires (soft sidewall, cushy ride?) & lack of suspension control (shocks)"
  14. #5034
    Nov 2005
    2,602
    "Tell him to add air to the tires & see if it changes. Maybe 5psi just to test it. If it improves any try a little more. But if they're like BFG radial ta with a max inflation of 35, don't drive it a lot with 45"
  15. #5035
    Sep 2008
    Whitestone, NY
    20,007
    Thats good info. Thanks Jim. And you caught me.
    I know Phil (brownmuscle) has already commented on the shocks about two years ago....They were newer even then. lol KYB gas a justs in the rear. Push down on rear bumper and car does not just rebound and stay put...it took a few up and downs to stop.
    It could be them.
    Tires are Yokohama Avid Envigor High Performance All Seasons 235/60/16. I will look into upping the tire pressure by 5psi and seeing how things go.
    If pressure does not fix the dribble (as that is precisely what it feels like) I will look into finding out what my pinion angle should be...do it and then test..if still bad look for bilsteins for the car.
    A video of some prior wheel hop to refresh memories:
  16. #5036
    Nov 2006
    Dirty Jersey Yo!
    8,313
    Box Panther back to terrorizing the neighborhood
  17. #5037
    Sep 2008
    Whitestone, NY
    20,007
    Yessir.
    Buddy wanted some sound to show his kiddo back at home.
    I upped the tire pressure 5psi in each tire to around 36. Seemed to have alleviate a majority of the wheel hop. While moving it was just leaving straight black lines and no hops...could also be a flatter road. More testing needed.
  18. #5038
    Mar 2006
    Bedford, VA
    6,209
    I'd forgot what a good small block sounds like. Very nice.
  19. #5039
    Sep 2008
    Whitestone, NY
    20,007
    Thanks. I just cant understand how the audio gets a bit messed up when putting it into the editing program from the phones recording. Aside from that slight nuance I am quite pleased with how it sounds in person. What you hear is what I head but with some slight noise.
  20. #5040
    40,186
    probably something with the audio compression. Tends to make things have a slightly nasal sort of sound.
Tags for this Thread
