Page 232 of 232 FirstFirst ... 132182222230231232
Results 4,621 to 4,622 of 4622
Thread: My 1987 Two Door Crown Victoria AKA THE BROWN BLOB
  1. #4621
    Sep 2008
    Whitestone, NY
    18,341
    Two different size tire and wheel combos. The HPPs are 16" while the LX Sport wheels are 17". To answer your question the tires are kept on the wheels.
  2. #4622
    Sep 2008
    Whitestone, NY
    18,341
    https://www.ebay.com/itm/1978-88-GM-...6/330923861910
    I may look into these in the future as the JC whitney ones are no longer available. This last set was installed some time around 2010.
    These look nice despite being a GM part..should fit the bill.
    Quick note for anyone deciding to purchase a set. They come FLAT. This means the measurement you may take from your cars existing CURVED interior pull strap will be incorrect if you simply measure from end to end like I did. lol Use a seamstress tape measure from end to end so you get an accurate reading.
    I will say though they are NICE quality. They come with a metal band that will span the length of the strap from behind the door panel.
    Despite getting the measurements incorrect I think I will still be okay with installing the ones I have purchased. I measured my existing door panel pull straps at 16" so naturally I ordered the 16" version (again not knowing these come FLAT). When installing the current ones I am using I need to bow them in a bit in order for them to fit, so this means the 16" flat ones may work and provide just enough bow to slip a hand behind it and grab it. I am okay with it not bowing out as far as it used to as it will allow one to utilize the armrest more anyways.
    I will get around to installing them and finding out if they in fact do work out for me some time in the future.
Tags for this Thread
