    Originally posted by tjc78 View Post
    There must be an inside joke I'm missing
    Nope. just Logan being stubborn.
    Watch out with those B&M converters, I had one balloon on me and I know Eric's had problems with them as well.
    I'm running it. May "I told you so" comments commence once my bubble pops.
      Cleaned up my engine and o2 sensor harnesses today.
      Before:
      After some loving:
      Newer tubing some labels, scrubbing the connectors down and adding tape makes a big difference.
        Holy shit. That looks like brand new!
          I'm glad to see you labeled the O2 sensor plugs. You should avoid the issues I had when I went HO.
            Looks great Dave I love how you detailed you are with everything
              Thanks guys. And John, you had the o2 harness reversed and that was messing with the computer?
              Covered the front of the frame with rust encapsulator. Masked off any areas I did not want to get any paint on and went to town. Did two coats. Rolled it on for the open areas and in the tight areas I used foam brushes and aerosols. Next step is extreme chassis black paint. If anyone is curious...this was about 1 full quart of rust encapsulator.
              Just have to let this stuff dry for a day then I am good to go with the next step.
              I guess in the future I will take care of the control arms again. I painted them before I installed them however long ago that was. The primer is holding tight but the top coat is not. The primer was a sherwin williams self etch primer and the top coat was duplicolor caliper paint. The caliper paint is checking off.
              I will also treat the wheel wells with rubberized undercoating (front and rear) as I have a bunch of cans of it from eastwood.
                Nice! Looking good. The ceramic paint is great for higher temps, but tends to have poor impact resistance. Its probably chipping off from being hit by road debris
                Sent from my iPad using Tapatalk
                -Phil
                  \ And John, you had the o2 harness reversed and that was messing with the computer?
                  Yes. That's also what probably ailed Project 79. Did the exact same stuff.
                  Also. What did you determine as left and right? From standing in front of the car or left as in driver side and right as passenger?
                    Freakin beautiful!!! When I rebuilt the front suspension, I was able to get to the frame above the wheels, but not inside the engine compartment. That Eastwood Extreme Chassis black is glossy. I painted the '06 PI wheels with that. It's a kawinkydink that I am currently looking to replace my O2 sensor plugs after snapping the retaining strap thingys. Probably gonna extend them when I get my engine out. I now know what to look forward to when I pull the lopo out.
                      It hurts my brain that it could have been the cause.
                        I wouldn't count on it, there's been more then just project 79 that just didn't run right with similar mods, my 87 CP included, and I know for a fact it wasn't wired wrong.
                          Left is drivers side, right is passengers side.
                          Oh yeah its shiny! I have the rest of my frame coated in that stuff. Of course those parts are all dirty but when first applied it is MINT.
                            Before:
                            After some loving:
                            How'd you make those labels.
                            Originally posted by SVT98t
                              I have a DYMO Rhino label maker.
                                I was going to borrow the Brother label maker from work when the time comes. Pretty sure most of the OEM labels are covered in oil; or long gone.
