Page 247 of 248 FirstFirst ... 147197237245246247248 LastLast
Results 4,921 to 4,940 of 4956
Thread: My 1987 Two Door Crown Victoria AKA THE BROWN BLOB
  1. #4921
    Nov 2006
    Dirty Jersey Yo!
    8,119
    I know the Premium Sound unit in the CV was becoming non-functional as it got closer to decommissioning. I wish I knew this stuff because I would love to restore that unit, get a decent amp, and replace the speakers in the car.
    My neighbor back in the day found that adding an amp to his stock head unit (1984 Buick Regal) made a drastic improvement in sound quality. That would be my goal with the CV.
  2. #4922
    39,765
    The stock radio is good for something like 6 watts on the front channel and 12 in the rear. The premium sound amp was good for 20 watts max and it added an EQ curve. The JBL stuff was good for 40 per channel with an EQ curve. I expect the GM stuff wasn't grossly different.
  3. #4923
    Sep 2014
    Warren, MI
    6,109
    When stock, I switched just the premium amp in my '88 for the JBL amp and that was a huge improvement. Could be the EQ curve difference between the two but the clarity, image, musicality and presence was much better over the small black box to my ears.
  4. #4924
    Sep 2008
    Whitestone, NY
    19,512
    Installed the previously mentioned 12v aux port underneath the passengers side seat this morning.
    Pics of bracket here: http://www.grandmarq.net/vb/showthre...l=1#post848460
    I am super happy with the position. It travels with seat movement and does not interfere with anything in the least.
    It is not wired in as of yet.
    I built a power distro panel that will be mounted to the heater box via silicone...and the main panel screws into the metal siliconed brackets. It houses a fuse panel, factory panther junction block, ground distro as well as a relay. I know I will have constant power and keyed power available via the junction block. Unsure of how the fuses will be populated as of yet. Will all make more sense once I figure out where I am grabbing power from and how I wire it up..oh an pictures will help it make sense too. Hopefully I can silicone on the metal brackets tomorrow so I can give them ample time to dry before fiddling with it.
  5. #4925
    Mar 2010
    Lewisville, TX
    21,889
    Nice. Wire routing for this will be interesting.
  6. #4926
    Sep 2008
    Whitestone, NY
    19,512
    For the 12 aux plug?
    I thought so at first as well but it slipped underneath the seat rail and right through factory hole in carpet for power seat harness. I then routed it over to the sill panel along side the door and forwards to the passengers side kick panel.
  7. #4927
    39,765
    just need enough of a loop to let it move with the seat, but thats easy.
  8. #4928
    Mar 2010
    Lewisville, TX
    21,889
    That makes sense. Didn't know if there was an easy way to get around/over the seat track to the area where the power seat connector would be to prevent pinching it.
    I'd put a connector at this point as well to make removing the seat easier in the need it happens.
  9. #4929
    Sep 2008
    Whitestone, NY
    19,512
    Yep. I did that as I did not want to unbolt if removing seats. It can just come with it! As seen here:
    And this is what I have going on with the power distro in the heater box area:
    Luckily I do not even need that relay as I found a dedicated keyed power and constant hot in the p.side kick panel:
    Thank you unused police options? Or trailer options. Regardless. Perfect for my application of feeding the factory panther junction block.
    And this is where the power distro business will be mounted:
    Black smaller brackets will be siliconed into place. Larger bracket bolts to those and houses the business end of things.
    Also started working a seat belt reminder light as well as brake reminder light (also will assist if a line is blown out and fluid goes low). The factory indicators were removed when swapping to police cluster with the integrated gauges I install in them. This project is turning out really nice and clean looking. Still in progress but has been totally wired in and tested. Seat belt light illuminates off factory chime/timer deal and brake light gets ground from reservoir if fluid is low and/or when you have the parking brake engaged.....which is something I now use all of the time because of the manual trans.
    Attached Thumbnails Attached Thumbnails IMG_3366.jpg   IMG_3373.jpg   IMG_3374.jpg   IMG_3355.jpg
  10. #4930
    Mar 2010
    Lewisville, TX
    21,889
    Nice. Makes that easier to deal with.
  11. #4931
    Member WagonMan's Avatar
    Sep 2004
    Bridgewater Ct.
    663
    I just finished stripping my 89 LTD wagon. I cut as many plugs from the dash I could including the ones I sent you before. LMK if you need anything. Pete
    1990 Colony Park
    1970 HEMI Superbird
  12. #4932
    Sep 2008
    Whitestone, NY
    19,512
    Oh yeah. I was ecstatic when I found those two plugs and one was always hot and one was hot with key in run and accessory.
    Quote Originally Posted by WagonMan View Post
    Yessir. Will do. Right now I think I am good. Turned out the parking brake switch was still installed in my car but now I have a good spare in case things go south. If any future projects come up I will check with you first.
  13. #4933
    Sep 2008
    Whitestone, NY
    19,512
    Well. I flubbed that one. My meter must have been playing tricks on me as I was preparing to wire in all the bits to the power distro BOTH of the lines were constant battery power and not one keyed and one power as I have previously stated. Woops. NO biggie. Found a keyed power in the kick panel and tapped into that to trigger the relay to give full power from the other free line to the accessory position of the junction block.
    Here is that all finished up:
    Wired in two hots and two keyed to the fuse block. Only thing in use right now is a keyed power to the 12 aux port under the passengers side seat.
    I have spare junction taps if I need to switch things around. Green and gray connectors are keyed special so one does not accidentally plug things in the wrong spot.
    Spare pieces:
    All tucks up nicely under the dash under panel:
    Whats nice is that I can unscrew the four corner screws and service the whole shebang if I make any additions or changes. It has a service loop to drop nicely into the footwell.
    Then went to the trunk and installed some ferrule ends onto my amp...
    Before:
    and after:
    Just did the speaker outs, trigger and ground. I was not in the mood to disconnect power....The ferrules make nice connections over just the bare wire being crimped down in the terminals. Once I have the battery disconnected I will go for installing a ferrule on the positive.
    And a sneak peak of the idiot light gibberish I was spewing in the above post.
  14. #4934
    Sep 2008
    Whitestone, NY
    19,512
    Oh and that fm transmitter I have kicks ass so far.
    I have 104.3 tuned in on the radio and fm transmitter is tuned in at 92.1 and it blows 104.3 out of the water. lol
    Tuned radio to 92.1 and leave antenna in fully down position and it works awesome. You get noise between songs switching but for my ears and desires it works great.
  15. #4935
    Sep 2008
    Whitestone, NY
    19,512
    Finished up with the interior jobs I wanted to tackle.
    Got a 1966 mustang parking brake light installed as well as seat belt reminder light. Also relocated the tuner interface to underneath the ash tray. Even with ashtray open the cable connected to it clears with plenty of room.
    Brake light:
    Up close:
    Just held on with silicone!
    Seatbelt reminder:
    Up close:
    Held on with silicone as well using the factory grand marquis cut away for trip reset.
    And the quarterhorse relocation:
    Mounted with the factory rear ashtray screw!
    Also a video showing things in action:
    Attached Thumbnails Attached Thumbnails IMG_3397.jpg   IMG_3396.jpg   IMG_3395.jpg   IMG_3394.jpg   IMG_3393.jpg
  16. #4936
    Sep 2008
    Whitestone, NY
    19,512
    Noticed this ebay seller was making some cool intake plaques and plates. I messaged him told him my idea and he had no problem changing up his existing design for me to make thing easier to powder coat.
    https://www.ebay.com/usr/cjrpony?_tr...72.m2749.l2754
    So I picked up the plaque I had him make for me and am damn happy.
    This is what I had before:
    Stock lightning plaque that I powder coated to match the car. Nothing wrong with it just plain and boring.
    The plaque I picked up:
    Nicer but still boring in raw aluminum.
    Now media blasted to get it ready for powder:
    Coated in OEM wheel sparkle silver and Ford Blue and bright red powder tediously laid into the engraved portions:
    And all completed after some clear powder:
    It is not perfect as there are rogue streaks and hues of blue and red but it looks damn nice to me.
    Guess I gotta install it on the car now.
    Going to want to powder coat my spare lightning tubular upper intake. Luckily for me that one is already media blasted iirc. Kinda don't want to touch the engine if I don't have to though.
    Attached Thumbnails Attached Thumbnails IMG_3404.jpg   IMG_3403.jpg   IMG_3402.jpg   IMG_3401.jpg   IMG_3347.jpg
  17. #4937
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,573
    Sweet!
    10 Escape LTD. V6 AWD, K&N, Bullitt wheels.
  18. #4938
    Nov 2005
    2,573
    How is your knee?
  19. #4939
    I post a lot...
    Dec 2011
    Yonkers NY
    4,189
    Oooh glitter! Yes I like.
  20. #4940
    Sep 2008
    Whitestone, NY
    19,512
    Quote Originally Posted by mitymerc View Post
    How is your knee?
    I have good days and bad. I have been diagnosed with non hodgkins lymphoma b cell slow growing. I need to undergo an additional biopsy of my knee to determine exactly what type of cancer I have before I can begin treatments. I had a full body PET scan and it is only in my knee, inside my femur which is extremely uncommon.
    After the first biopsy I had to go to the ER room 15 days later as I was having chest pains. Pulmonary embolisms in both lungs. I am feeling fine now but that sucked to. Now I am on blood thinners for 6 months. Luckily though this is found early and shouldnt be a problem. I feel fantastic otherwise. Just my knee making thigs extremely difficult and uncomfortable.
Tags for this Thread
