Page 243 of 245 FirstFirst ... 143193233241242243244245 LastLast
Results 4,841 to 4,860 of 4881
Thread: My 1987 Two Door Crown Victoria AKA THE BROWN BLOB
  1. #4841
    Sep 2008
    Whitestone, NY
    19,231
    Quote Originally Posted by mitymerc View Post
    Guys at the track used to put me in their cars and be confused that I picked up a tenth or two. The beater idea is a good one, if you are afraid to break it, you'll never shift quickly.
    Also, the feeling of a good launch & clean powershifts is the most fun part of drag racing. (imho)
    If you have the time a member here by the name of MR.Blue (or something awfully close) has a youtube channel https://www.youtube.com/user/50tussin and would definitely entertain you. He is all about the 1/8 mile and powershifting his clapped out mustangs. Very fun and down to earth guy to watch. I am concerned though as there has been no activity from his youtube channel since this covid stuff started. Regardless his content is fantastically substandard entertainment.
  2. #4842
    39,366
    I'd be the guy that would lose a few tenths because I dislike the notion of breaking stuff. I can and often have driven without even using the clutch by rev matching the engine. Its not exactly a rapid gear change process but when you drive things with clapped out synchros its the only way to do a gear shift without a "grind it till you find it" situation.
  3. #4843
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,503
    Clutchless shifting is fun & takes skill.
    10 Escape LTD. V6 AWD, K&N, Bullitt wheels.
  4. #4844
    39,366
    or just a need to get around for several days with a busted clutch cable until payday.
  5. #4845
    I post a lot...
    Dec 2011
    Yonkers NY
    4,161
    that is a professional way to shift for large trucks. I have no manual vehicles now but when I do clutches are for 1st gear.
  6. #4846
    Sep 2014
    Warren, MI
    5,941
    Begs the question, if the clutch cable is busted, how the hell do you get the vehicle started and what do you do if you have to stop?
    Quote Originally Posted by jaywish View Post
    Well yeah, the flywheel and input shaft and all that are super heavy so there is a longer time window to get the shift right, not to mention they don't have synchros. If it's a light duty transmission and if everything is in good shape, don't do that lol. You're only going to burn out the synchros more. At most, I'd rev match going 1-2 with an M50DR1, and only when going super slowly.
  7. #4847
    Nov 2006
    Dirty Jersey Yo!
    8,004
    I had a friend that said that to me quite awhile ago. If he absolutely needed to win a race, he would run the RPMs up past the shift point and bang the gears. Didn't tell me if that made a positive difference.
  8. #4848
    39,366
    shut the engine off, jam it in first, start the engine. I'm sure thats not wonderful for the starter but if the engine runs decently it will catch and go pretty quickly. This was something built long before safety switches, so it had no issues with being started in gear with no clutch.
    You can pop them into neutral without much fuss, and with practice you can rev match for downshifting. I won't lie and tell you its easy or a lot of fun but it can be done if there isn't any choice in the matter.
  9. #4849
    Nov 2005
    2,503
    I used to drive em home broken. One time I lost 3rd at the track, went 1, 2, 4, 5 till I lost 4th as well.
    1 gear, 2nd geeeeaaaaarrrrrr, fifth. Then 2nd went away LOL. Still made it home.
  10. #4850
    Mar 2010
    Lewisville, TX
    21,657
    Did that with that POS Suzuki I used to have. Lost 2nd and 1st was a granny gear and 3rd was hard to reach from 1st. By the time I was able to get it to the shop, I was 200miles over the factory warranty (had an extended warranty and ended up with a new trans for $200 - worked out for me)... but driving by ramping out 1st gear to lug 3rd was rough.
  11. #4851
    Sep 2008
    Whitestone, NY
    19,231
    Some tire chirpin' and spinnin' for you guys:
    Chrips the 1-2 no problem spins even if you stay on it. Still a noob.
    And some pics:
    Attached Thumbnails Attached Thumbnails IMG_2960.jpg   IMG_2962.jpg   IMG_2963.jpg   IMG_2964.jpg
  12. #4852
    Nov 2005
    2,503
    Keep up the good work!
    Did I hear a bark on the first 2/3 shift?
  13. #4853
    Sep 2008
    Whitestone, NY
    19,231
    Yes you did.
    Also on the 5 4 down shift. But that is just drivetrain abuse at that point.
  14. #4854
    Nov 2005
    2,503
    Even with double downshifts I never liked to make it bark.
  15. #4855
    Sep 2008
    Whitestone, NY
    19,231
    Did an oil change, drained the PCV catch can and swapped in a new motorcraft IAC and coil in place of the old ones.
    Coil was an MSD blaster coil I believe. It was showing signs of aging..visual aging...splitting epoxy and such so I ditched it for a motorcraft unit. Looks nicer in the bay to boot.
    Found out the fan clutch has seen better days. HOT HOT HOT and it likes to spin too much for my liking. Off to rockauto I go.
    EDIT..Any recommendations on fan clutch?
  16. #4856
    Nov 2005
    2,503
    I used the police one on one of my fox cars. Supposed to cool better st lower rpms.
  17. #4857
    Sep 2008
    Whitestone, NY
    19,231
    Search under the 351 engine? Compatible like that?
    EDIT
    Not finding much variety on the panther chassis fan clutches.
  18. #4858
    39,366
    You might get slightly better AC performance from a non-thermal since it will be engaged all the time at lower speed. Thermal clutches will drop out until they get hot enough.
  19. #4859
    Sep 2008
    Whitestone, NY
    19,231
    Lets say yours needs to be replaced. What are you purchasing?
  20. #4860
    Nov 2005
    2,503
Tags for this Thread
