Page 134 of 234 FirstFirst ... 3484124132133134135136144184 ... LastLast
Results 2,661 to 2,680 of 4673
Thread: My 1987 Two Door Crown Victoria AKA THE BROWN BLOB
  1. #2661
    Oct 2008
    Buffalo, NY
    4,962
    Nice work Dave. That box is a lot stiffer isn't it? Every time I go to drive the 89 compared to my other cars I'm like "holy crap".
  2. #2662
    37,595
    I got the big addco 1 1/4" bar...I also didn't want to fight around it or mess up the coating on it. Figured it would just be simpler to get it out the way.
    Ah. Old rusty wagon bar on mine. Not much concern about the cosmetics of that thing.,
  3. #2663
    Apr 2010
    Southern NJ
    2,544
    Nice install, let us know your thoughts once you get some seat time.
    Past Panthers
  4. #2664
    18,491
    Seat time was today after the wet/misty weather passed.
    Took it out an within a few blocks I realized that the steering wheel was off center. I remember hearing about this from another member.Mine was at the 11 o'clock position coincidentally so was his...
    So I turned around and headed home. Got out the toe plates and proceeded to get my steering wheel centered. Took a couple times to get it right. 5 times for me to be exact. After each try I take the car for a spin and see whats up. I loosen the adjusting sleeved and make sure the wheels turn in the direction of where the steering wheel is wrongly pointing. This gets your steering wheel centered and when you do each side (adjusting sleeves) evenly your toe goes unaltered.
    I then took the car out for a speed run. I felt a helluva lot more confident with this nice stiff steering box than I did with the stock one. I say if you like going fast around long curvy roads that this is a must. Nice response/feedback from the wheel. It is like there is just enough resistance to help you stay in control and turn the wheel only as much as you need to. With the stock box it is very easy to turn it to quickly, this new box eliminates that problem.
    Another nice thing about the mod is that if you are on the go pedal while hitting a rough patch of road you no longer sway back and forth because of your body being thrown around. The steering has enough stiffness to eliminate that problem almost entirely. I know with the stock box and me making turns spiritedly that I would normally have the car going wherever my arms were being tossed from the road. Now all gone.
    I like it. I have already become used to the stiffer steering and it is not much of an annoyance on simple turns around town.
  5. #2665
    Do a burnout, pussy. Bobcat's Avatar
    Jan 2013
    West Granby, CT
    1,266
    Yeah, it's like night and day when I get in my box compared to my whale.. They box you can steer with a pinky while as the whale you have to muscle it around. Well and the fact that I think my power steering is on its way out on the whale.
    Quote Originally Posted by SVT98t View Post
    18,491
    Quote Originally Posted by Bobcat View Post
    Clean install, might I ask what the reason was for doing this? Firmer steering? Or..
    Thanks Logan. Yes. And boredom and just because it can be done but mainly for the tighter steering.
    Thanks. Yep. First time I moved it I was shocked at how heavy it was.
    I am pretty paranoid about keeping nice looking things nice looking.
  7. #2667
    37,595
    The old box had enough slop in it that I expect you'd have gotten noticeable improvements just from a fresh one. I like the stiffer steering too though, with most of the same reasons why. The hyper-sensitive steering really sucks if you sneeze at speed. I've nearly run people off the road from that before.
  8. #2668
    20,961
    I typically let go of the wheel for that split second just so I don't swerve... or jab my elbow into the armrest on the door as I sneeze.
  9. #2669
    Jan 2013
    West Granby, CT
    1,266
    I may look into doing this.. I somewhat prefer my dead weight steering on the whale.
    Nov 2006
    Dirty Jersey Yo!
    7,746
    That was the second repair made to my CV. Though I replaced mine with a stock steering box. It was not long after that I noticed the hyper sensitive steering. I didn't know at the time that the old box was that worn out. I attributed it to an aged suspension that would cause the CV to wander on the highway. In any event, after I changed the front suspension, all that went away.
    18,491
    I have no idea how this stiff steering box would compare to the rack and pinion steering feel of the Whales...Whales do have racks right???
  12. #2672
    Jan 2013
    West Granby, CT
    1,266
    Indeed, I enjoy the stiffness when cruising but when backing into a spot or something alike; it gets old. Though I do believe my power steering is screwed up a bit. :shrug:
    18,491
    You just need to work up muscle. Last time I seen ya you were skin and bones. lol
  14. #2674
    Apr 2010
    Southern NJ
    2,544
    03+ is rack and pinion, definitely stiffer than a stock box with a better on center feel.
    Past Panthers
  15. #2675
    Jan 2013
    West Granby, CT
    1,266
    I'll show you, you - me Scottfest.
    But on the realistic side, my dad even drove the car before I had my license and was freaking out because it "Had no power steering"
    37,595
    The rack and peanut is stiffer than pinky steer, but a lot more vague feeling. They don't self-center worth a damn and the turn radius is increased over the steering box setup. Personally I very much dislike how it feels. The late CVPI steering box is much more positive feeling.
  17. #2677
    Jan 2013
    West Granby, CT
    1,266
    Late model CVPI wooo!
    The lacking all luxury options isn't fun though. I guess I'm lucky I got one with a power drivers seat.. High options, lol.
    and a few electrical problems.
    Jan 2013
    West Granby, CT
    1,266
    So I had some police dash gauges given to me from my dads friend to happened to have them just laying around for the past 30 years and didn't know what they were..
    How did you go about mounting them? Did you cut the dash for the wiring and bolt the gauges in? Any pictures of that err?
    18,491
    What style do you have? The 88-89 plastic one or the metal, 87 and down one?
    I installed both into my car years back.
    I cut a hole in the panel and relocated the auto climate sensor and siliconed in the 88-89 style. Then I picked up the metal 87 and down one and screwed that one in.
    You have to cut up the dash behind for them to fit.
    Here is my first install:
    http://www.grandmarq.net/vb/showthre...uipped-vehicle
    Currently:
  20. #2680
    18,491
    Getting the old gal ready for another year at SF tomorrow. Hope the weather stays perty so she can stay all perty for the event.
Tags for this Thread
