that is awesome!
And here is the new list of shit to install on this car.
- Chevy. GMC Truck Sport Lower Valence (Has fog lamp holes)
- Sexy mini Marchal fog lamps from Rangers/Escort GT's
- Addco 509 1 1/4 Front sway bar with enlinks etc.
- Stock Box Panther Police Oil cooler
- Big brake upgrade/ Complete with Energy Suspension Poly Bushings I had installed over at Scotts
- Engine mounts
- Ford Racing 3.73's Complete with ford racing install kit
- Trac Lock Clutch Rebuild kit
- Ford racing rear dif cover
- Tubular GT 40 upper intake with matching lower
[* Fuel Injector Rebuild Kit - Lightning EGR Spacer with matching lightning 65mm throttle body
- Motorcraft thermostat
- Motorcraft PCV valve with new pcv screen and grommet
- Cast Aluminum Mustang Valve cover (a different set to be painted with VHT wrinkle paint)
- Crane 1.7 Roller Rockers
- Ford racing 1/2" intake spacer
- Repainted 1979 Specific License Plate housing
- Sexy color matched to car rear license plate cover (like the one on my Escort)
- Town Car Underseat courtesy lights
- HPP wheels!
- HAVE TO FIND DRIVERS SIDE FENDER..Mines rusting like a banshee!
I think that is this bulk of everything.........Last edited by 87gtVIC; 03-03-2013, 03:28 AM.~David~
Originally posted by 87gtVIC View PostI have no clue what my car can tow.
That hitch looks like the older version of this one.
http://www.summitracing.com/parts/ch...crown-victoria2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
The hitch is a handy thing. I've used mine a few times, but not nearly what it used to be used for. My car was bought to tow a 2 horse trailer. I've pulled two Towncars and my S10 on a tow dolly at different times with it. I've also used it to haul a fair size flatbed trailer when we were moving. I don't back stuff down the ramp because I don't want the salt water on the car but I have little doubt it would do what I ask as long as I got traction.86 Lincoln Town Car (Galactica).
Did more work today.
Installed the Lincoln Town Car Under seat courtesy lights! Since the seats were out I also tapped out a seat mount hole for a bigger bolt as it was stripped.
Can't see much:
And I cleaned up the interior and took some new photos.
Originally posted by pantera77 View PostHD Tow package cars are rated for 5000lbs, 5.8's for 6000lbs.
http://www.summitracing.com/parts/ch...crown-victoria~David~
Nice and clean as always! But, how do you already have a rusty fender?
It was rusty before, both of them were. I cut out all the rust I saw at the time but other areas had rust that now showed its ugly rust head. I should have known that where there is some rust there will be more. It sucks but oh well. I have a minty p.side one already. I just have to find a d.side one that is just as nice. It definitely was a learning experience.~David~
Looking good. Sucks about the fenders. What's the plan? Install new ones and paint/blend to match?2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
I am not sure what the plan is. I really want to wait on putting the fenders on until AFTER i have new engine installed. When that is, who know? Having the parts in my possession though is half the battle. I planned to take the entire front clip off and fix whatever needs fixing and install new engine then.~David~
Finished making my gt 40 tubular intake cover. This started as a flat sheet of aluminum and after some jigsawing, filing, bending, welding, grinding and sanding you have this:
It is getting painted tomorrow.~David~
Originally posted by 87gtVIC View PostI am not sure what the plan is. I really want to wait on putting the fenders on until AFTER i have new engine installed. When that is, who know? Having the parts in my possession though is half the battle. I planned to take the entire front clip off and fix whatever needs fixing and install new engine then.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
you have one hell of a car.. that thing is amazing.. you sir are missing only one thing a subCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Agreed. I'd like to have a small sub with the amp built into it. I just do not know what type to purchase. I think bazooka sells/sold? subs with built in amps? A little bump is really what the audio system needs.~David~
