what maf do you need to match on that?
Not so sure how that all works but a 24# maf I would have to guess.
I'll probably have to purchase a marauder air box as well because mine has the card style maf. All of the other mafs I see are different.
Now I see 24# mafs come in all different size tubes....mm wise. I don;t know what that means or if it makes a difference.~David~
oh boy/....Just purchased a MAF from an MKVIII...one step closer.~David~
use a stock MAF and tune the ECM to match the injectors. The "calibrated" MAF just feeds a modified signal to fool the computer into thinking its getting less airflow in order to shorten the pulse on the injectors so they more or less work right. It doesn't really fix it 100% and it won't optimize fuel or spark curves to an engine that actually needs more injector. If you're running a MAF other than what went with your particular ECM, you program the MAF curve into the ECM and you're golden.86 Lincoln Town Car (Galactica).
David, you will be doing an engine swap in no time! None of this next year crap
Highly unlikely. I want all of the suspension stuff done before the go fast stuff.
Thain I understand what you are saying. I see there is a lot of confusion surrounding the net with how mafs work. I see aftermarket mafs are calibrated to trick the computer, ford mafs are just mafs and the information is changed in the computer to work with the maf. At least that is a very rudimentary way af me describing maf.~David~
Originally posted by 87gtVIC View PostHighly unlikely. I want all of the suspension stuff done before the go fast stuff.
rebuilt ford/ denso 24# injectors came in today! Made me pull out the fuel rail from the shed. Will clean it up tomorrow and maybe even paint it the as well. If not paint will happen Friday.
Also picked up a set of NIB Ford Racing 3.73 rear gears for a song.~David~
Looks nice and clean. It's probably already answered somewhere in this thread, but what cam are you using with 24 pounders? And are you using an A9P computer?1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
Thanks...that is just the tip of the iceberg......you wait until everything is bolted onto that engine.....a year or two from now. lol
A9P and here is the part number for the cam: TFS-51403001
It is the cam from the TFS Top End kit from Summit.~David~
perty
Sweet!!2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Welp...TFS 170 heads are on the way......got a deal on a new set through the corral.~David~
nice
