    Looks good. Never realized the trim holes were different between the GM and CV, but its never something I had to learn. Seems like they would have designed it to use the same trim mounting holes just for economy reasons.
      the 88+ Grand Marquis use those ugly black rubber pieces That run along midway of the body. The trim for the vic was the same 79-91 and the mercury also used that trim up to 87.
        Yep the 88+ Grand Marquis had to be different...
        More progress today.
        Sanded off the fiberglass filler:
        And applied some evercoat rage body filler then sanded that off:
        I also sanded down all of the previously rust converter treated areas and applied rust encasulator to it:
        I wanna get this thing in primer before I go away to Tallahassee for a weeks worth of Nerd convention..I mean league of legends invitational....We have a truck working there....
          how bad are your fenders on the car now
            Shitty over the wheel arches.
            Passengers side is better than drivers. Both sides had the rust cut out of them then packed with long strand fiberglass filler. Passengers side is bulging out and bubbling some. Drivers side the same but also complete rust through in areas that were spotless back in 2010 when the paint work was done.
            More prep work today...consisted of sanding everything down with 220 the a red scotch brite on all the areas to be primed.
            Check out my kick as stand:
            And ready for primer:
            Back side will be primed on all the white as well as the area next to the battery:
              Took my NOS centercaps out of their seals and cleaned them up and applied some wheel wax to them to deepen the shine and make them easier to clean if the wheels ever get back on the car...
              Before:
              After:
                Epoxy primed the passengers side fender today as well as started working on the drivers side one.
                My babies:
                Passengers side all primed up:
                Will guide coat it and block it out once I get back from my work trip.
                The back side of the drivers side fender was dirty but nice and rust free:
                The ditch light area was fucked up. Lots of bondo in there. I ground it all out and hammer and dollied it out as best as I could:
                Me just before slinging some mud:
                Done with the body work and the little bit of rusty areas sitting in rust convertor.
                Rust encapsulated the back side some just because:
                Will go over the rust converted bits with rust encapsulator once I get back from my work trip.
                Now to order more 2k primer....
                  the more I see you work on this car, the more I realize how far to the other side of the spectrum I am with mine. I need to clean mine out BAD.
                    Looking good dude!
                    You're fenders rotted out that bad since 2010? Don't you not even drive you're car once it becomes winter? I know my fenders aren't bad but now you have me afraid to even take a hard look at them this spring!
                      Hey, there are some smokin' hot chicks on those conventions! Been trying to get mine to go to one of the anime ones and show them what a proper Black Lagoon Revy looks like, but so far no luck... Ah well, at least I get to take Shenhua out for dinner every once in a while, so not all is lost
                      Crazy amount of work you're putting in that car, pretty sure by the time you're halfway done with everything she will already look better than when she left the assembly line. Attention to detail is nothing short of impressive, wish I had that kinda patience and determination... Keep it up, some of us enjoy Panthers vicariously thru folks like yourself
                        Thanks. Its easier when its not my daily.
                        Originally posted by slack View Post
                        Looking good dude!
                        Sure they were painted some years back but they are still really old. I had not pulled the fenders off the car when painted to really get a look in them for more rust damage caused from many years of year round dding it.
                        I don't drive the car in winter or rain. Hell I don;t even wash it. I do waterless car washes.
                        Super happy the two I have to go on the car are nice and clean. I will also oil the hell out of the inside of them to ensure they stay that way no matter what.
                        Thanks for the kind words.
                          Probably condensation coming up off the ground and settling inside and under the body panels. My friend with the '67 Velle told that he had to put a tarp under the car and pin the sides of the tarp along the garage wall to keep the condensation off of the car. That's in a garage in addition to a car cover.
                          Yah, once it starts, it all just goes downhill in a hurry. I noticed a little rust on the lip of the lower pass rear fender on my '86 CV, is now completely rotted through. I lose a good amount of metal/rust every winter due to the salt and potholes. Once I get the new engine in, I will immediately hunt for a rear pass fender and a front driver side fender.
                            Now that I came back from Tallahassee and got some rest (just under a 120hr work week!) I got back to worrking on the drivers side fender.
                            Yesterday I filler primed the ditch light area after scuffing and painting with rust encapsulator the previously rust convereted areas. Today I block out that filler primer to get the ditch light area more straight. Still ain't perfect, and wont be, but should be fine in the end. I used a nice dry powder guide coat. Worked great.
                            Here it is right before primer:
                            It was not easy getting to that point. Went over the entire piece with 80 grit then 120 then 220. Scuffed everything really well with a red scotch brite and the primed it with 2k epoxy primer.
                            Here she sits. Will let that fender dry a couple days before blocking it out.
                              Nice work!!! Wish I had the patience (and a steady hand) for that.
                              Who's foxbody?
                                Best years of the fox. The four eyed.
                                Is it a cobra? Those look like cobra wheels...
                                Originally posted by SVT98t
