    Looks great Dave.
    I just ordered some stuff from Express Paint the other day to touch up the chips on my 85, and to paint some rust on the 92.
      they sell paint-on rust now? Shit, all this time I've had to wait for nature to take it's course. Screw that noise. I'm buying me a brandy new truck and some paint-on rust next week.
        That came out pretty good for a spray can paint job. Is your paint a metallic? Those are a pain in the ass to spray and not have weird shades afterwards.
          Thanks all.
          Yes the paint is a metallic. Paint code is A88. Hot Chocolate Metallic/Pearl depending on manufacturers. Luckily express paint's spray cans come with a fan pattern to help limit any potential tiger stripping. I've been doing this long enough to avoid making that mistake. Silver/aluminum metallic colors still gets me though on some of the parts I paint. I honestly would not try a large panel with one of those colors.
          The spray max clear comes out just like a spray gun. Nice and heavy and wide. The primer was the same. Both were 2k products just like you would use in a gun. This is just like a professional spray job, just diy at home.
            Just for my own curiosity, what do they charge for a can of the base coat. It can't be cheap.
            Past Panthers
              If I have the correct stuff, this may help....I think it's like $15 or so a can...
              http://www.expresspaint.com/
                It;s 24 bucks a can. Not cheap.
                Went junkyarding today with great success!
                Pulled tudor grand marquis under-armrest trims, 87 and under box cv header panel, a pedal assembly from the same 85 CV Slick top cheapie base model, in addition to a clock delete panel from that same vehicle. Pulled a number of large radiator brackets (as I have to make one fit my three core radiator I have in the parts stash), a idler bracket and the big aluminum bracket that hides behind it, 3 box panther throttlebody linkages (to be welded onto larger Mustang/lightning throttle bodies). I am happy with what was scored.
                SOme pics:
                My header panel and under armrest trims
                The car the pedal assembly was pulled from in addition to the clock delete plate and the header panel...:
                And the find of the day:
                I should have pulled some of the tudor specific stuff......Doors were shot. Drivers side was rusty and the passengers side was bent over from contacting the fender.
                  I wish I could find nice headlight buckets . Turn lights and a grille. All mine are shot. Esp the corner lights
                  -Nick M.
                  Columbia, SC
                    Nice stuff. I'll have to look into that paint.
                    Any plans for the delete plate?
                      Idler bracket, the one for the AC side ?
                        I went by the site price of $14.95. Did you get larger cans or are you including shipping?
                        http://www.expresspaint.com/automoti...e&resetValue=Y
                          Hording it.
                          Yep and the big honking aluminum braket for the ac behind that one.
                          Not including shipping. Bottom line price for ANYTHING is 14.95. Then the price gets higher for whatever product type/paint size you select.
                            Were the door pulls in any somewhat decent shape? That passengers side looks good...
                            Should've gotten the coupe specific trim.
                            Originally posted by SVT98t
                              Honestly I didn't even notice.
                              Today I fabbed up my radiator hold downs for my three core radiator:
                              Just a little bit needed to be trimmed out of the center. Rubber pads received the same treatment.
                              Both are now welded and I seam sealed the weld area and will paint it up when I have a chance.
                                The radiator was smaller?
