    I want to repaint the wheels and then get some sticky sticky performance tires for them.
    Bout 100 feet long easy.
      Originally posted by p71towny View Post
      It is no longer the brown blob. Hence forth I dub thee......
      [ATTACH=CONFIG]42945[/ATTACH]
      Remember https://en.wikipedia.org/wiki/Darryl_Dawkins
      1987 Grand Marquis LS two door, trying to get to the 60,000 mile mark.
        I want to watch those videos but my computer no wanna workie!
        Love your car man! Interesting about that whine, I always thought it was the trans too, just figured it was a ford thing. WhiiiiiiiiIIIIRR-whummm ->first then into second noise
          You can see the pics though right?
            Is anything wrong with the lopo in it now? Seems like it runs pretty smooth from the videos. Smoother than mine, mine is erratic from the vacuum lines all gone, and I haven't done a tune up yet. Still gonna stick with the lopo, just replace the lines and do a tune up, plus HO upper/manifolds and catless downpipes. Gonna be tough getting used to the lopo after my 270hp/320tq 4Runner, have to fight the urge to instantly throw money at it like 4.10 gears and a new engine.
            If you're going to junk the engine, it should go out with a bang. Hook up a cheaply made nitrous kit to it, see how much it'll take before it melts the pistons or has explosive diarrhea.
              I approve of the burnouts..
              Originally posted by SVT98t
                Love that you returned to the scene of the crime the next day.
                  Nothing much wrong with the lopo aside from it lacking ho power. Oil pressure is a bit lower then I would like, aside from that it is a fine running engine. Plans are to rebuild that one for my dad.
                  No shit. lol
                  Further evidence was needed!
                    So why haven't you built the motor yet for SF? C'mon now, you could have that thing already done and driving, in a couple days time.
                    Ask me how I know.
                      Still in its box. I am slowwwww. Been doing a significant amount of yard work and shed shuffling within the backyard hindering progress to the max. I prefer to tAke my time as I will also be detailing the frame rails. Motor will be painted and the assembled then installed. Much wiring to be done at that time. Ian in no rush either. Next sf if I am not in Brazil already (Olympic games for three months....and more importantly banging Brazilian women for that same amount of time) I will bring the Vic with its completed engine.
                        I can see pics! I envy the progress. I am stretched in multiple directions but I really want to at least throw the HO upper on my turd before the salt flies...
                          Your absence will be excused for this reason, however pics or it didn't happen. Of them, not you
                            You got it.
                            Did a little work on the Vic this morning...replaced a tachometer illumination bulb that has been flickering on me the last two time I took the car out and I re-tuned the amplifier to my liking...again. I loaded up some stuff for scottfest inside a faux trunk organizer that was pulled out of a truck at work. After all that I started to make some progress on the engine build by building the stand and crane.
                              reading the destructions? wtf?
                              Small tip if you didn't work this out already, but put some oil on the wheels, both at the axle and the pivot. Makes moving the crane around much easier, especially with a little weight on it. I use gear oil on mine, and on the jack as well.
                                I tend to use axle grease on that stuff... stays put better.
