    If its tight it'll do OK with 5w30, if the oil pressure sucks run 10w30. Mine isn't super tight and it does fine with 5w30. I think I'm around 20 psi hot idle in gear, and thats fine. It will hit the pressure regulator at much above idle.
      are you going to bring it to the guy to be fine tuned? 10-12 is rich as shit, 12 is acceptable WOT, 10 is too rich no matter what you're doing. he could have this tuned fully very quickly in person
        What weight does builder specify?
          Big steam
          Originally posted by SVT98t
            Big steam
              Steam oil is thick shit. I doubt thats the right grade.
                  Nope. He's in the Carolina's. I still never driven it around so I have no idea how it does with a load on it in any gear. Its a back and forth game until we get it right.
                  Short block from LMR. They don;t recommend anything. Put what you want in it.
                  Originally posted by Bobcat View Post
                  Big steam
                  Woot.
                  Big steam
                  Chooo-chooo
                    Chooo-chooo
                    There's a Mighty Car Mods joke here...
                      Touche. Looks like he needs raw crude oil.
                      I run 10w30 and wouldn't go any thinner, since roller rockers make some good noise when hot.
                        That is what I thought when I typed it.
                        Copy that! Think I will stay with a 10w30 and go synthetic.
                          John and Phil
                          Here is a datalog from my car:
                          Looks like the TPS readings are inaccurate as I have the thing set EXACTLY at .98 at idle.
                            Looks great Dave
                              John and Phil
                              You have it set at .98 by what the computer sees? Or by a voltmeter? Use Binary editor with the key on to se your tps. And set it to .900v if you can. That's where I personally like to set mine.
                                by my power probe.
                                BE sees that as 1.27
