Page 236 of 245 FirstFirst ... 136186226234235236237238 ... LastLast
Results 4,701 to 4,720 of 4895
Thread: My 1987 Two Door Crown Victoria AKA THE BROWN BLOB
  1. #4701
    19,325
    over about 85F I wouldn't expect the compressor to cycle if the blower is on full go. If yours is, it probably wants a little more juice. It does usually want a couple minutes of run time before things settle though. You can see that on the gauges if you turn it on from sitting.
    Are yours the fittings that have the push rod that just pokes at the valve in the R12 port? Those seem extra prone to leaking. I like the kind where you pull the stem out of the R12 port and the 134a fitting has it's own.
    Just at the low side has the push rod. I removed the fitting and it still leaks at just the r12 port on the drier.
    The high side fitting I placed an adapter that just goes over the whole deal no extra schrader.
    Either way the leak is extremely small but present none the less.
    Any way you can comment on the video I have linked to my cars gauges in action?
  2. #4702
    39,562
    Pressure might be a bit low, if thats at idle the low side will swing further down with throttle and the compressor will probably start to cycle. Drop-out is somewhere in the 20-25 psi range and it looks like you're right there. low side will be higher if the blower is at full go because its dumping more heat into the evaporator. The high side pressure should tend to be a little lower with the new condenser vs the old style just for efficiency reasons.
  3. #4703
    19,325
    That video is at idle with fan on low.
    I also picked up the conversion fittings for eliminating the r12 schrader on the low side...My high side conversion fitting utilizes no extra push rod schrader. I also have new schrader valves ready to go. Last step is picking up a big ol jug of r134a. Thinking of just picking up a 30# one. Cost seems extremely fair.
  4. #4704
    21,753
    Yeah... you need more gas in there. You shouldn't be able to pull below 30psi at idle... and preferably 35psi.
  5. #4705
    19,325
    Excellent. All things to look for. Much appreciated. We'll see how long the juice stays in before I completely suck down the system, change out the schraders valve on the high side and remove the schrader and replace it with the new adapter on the low side.
    IN other news....
    The 2.73's made it late. lol
    An I wonder what paint color the other 25 cars had that wore the brown vinyl top?
  6. #4706
    GMN Regular slack's Avatar
    Mar 2013
    Long Island, NY
    1,266
    Wow only 4 cars made with that paint and trim code. That's pretty crazy! Yours is probably the only one left out there.
  7. #4707
    Sep 2014
    Warren, MI
    6,018
    Yeah, my thoughts exactly. And I thought my Town Car was rare.
    A Trac-Lok 2.73. Cool. Didn't your dad order that car new?
  8. #4708
    5,816
    I didn’t realize your car was a leather to begin with.
    I’ve been crossing the ancient production numbers in my signature with kishy’s reports and they have been correct. What boggles my mind is that, according to this one, there would have been over 1000 351 tudors in 87 which seems excessive.
  9. #4709
    19,325
    Not quite. My father serviced it since inception. He worked at Universal Ford.
    I was pondering the same about the engine situation. Makes you wonder what numbers are correct.
  10. #4710
    5,816
    I’m gonna lean on Marti being correct. Mine came out of a book I found at my parents house from 1996. I am wondering about the LX designation for tudors in 1987. Maybe most of that missing 1000+ are non LX deuces?
  11. #4711
    39,562
    I wonder if its actually a 1 of 1 if you figure the other mix of options and such. Wouldn't be hard to get from 1 of 4 to 1 of 1. The traction lock alone might do it.
  12. #4712
    19,325
    We may never know. I was surprised seeing that figure to say the least.
    AC still works good. 45 vent temp in this SUPER humid day.
    And a quick shot of the hood hinges that I mentioned previously:
    Makes me want to strip the cowl and firewall and shine all that up.....aint gonna happen....
    OH almost forgot..in the engine bay shot you can see my powder coated lightning engine plaque:
    It was powder coated gloss black then mocha metallic. Kinda matches the car!
    Old one that I painted was failing:
    Did it all myself After stripping the previously painted one:
    Ready for powder:
    Attached Thumbnails Attached Thumbnails icy ac.jpg   Hood hinge left.jpg   Hood hing right.jpg   powder lightning.jpg   lightning plaques.jpg
  13. #4713
    21,753
    Color matched engine plate. Nice.
  14. #4714
    Nov 2006
    Dirty Jersey Yo!
    8,048
    Beautiful!!!
  15. #4715
    Apr 2010
    Southern NJ
    2,686
    Love it.
    Past Panthers
  16. #4716
    Member BigMerc96's Avatar
    Jun 2011
    I can see Detroit from here
    516
    Buying a 30# cylinder requires an EPA license. There were a bunch of changes in the regulations on refrigerants effective January 1st, 2018, and that is the biggest that effects automotive. The other one that you'll encounter is that all r134a cans manufactured after that date must have a self-sealing valve on them, so if your gauge/hose setup is made to pierce the top of the cans it likely won't work with the new cans without an adapter (but the adapters are cheep, ~$3 at most parts stores). Of course, if you do HVAC or mechanic work professionally, you already know this and probably already have the license, just throwing it out there for those who don't.
    -Steve
  17. #4717
    21,753
    Interesting. Still been seeing the pierce top cans in my area at the FLAPS and Wally World.
  18. #4718
    19,325
    Quote Originally Posted by BigMerc96 View Post
    I have the bottle in my possession.
    Yes about self sealing cans requiring new adapters. Had it all ready.
    I am no professional. Just an idiot with a bottle, a scale and a set of gauges.
  19. #4719
    Jan 2007
    Westmont, New Jersey
    10,381
    Willing to let one of those lightning engine covers go?
  20. #4720
    19,325
    Nope. I knew you would ask.
Tags for this Thread
