Page 251 of 253 FirstFirst ... 151201241249250251252253 LastLast
Results 5,001 to 5,020 of 5043
Thread: My 1987 Two Door Crown Victoria AKA THE BROWN BLOB
  1. #5001
    Jan 2008
    New Jersey
    3,111
    Very nice. I always wanted a cruise control on status light when I had the station wagon. But never really looked into it in depth
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,725
    What I used to do with 8 track and cassette players is clean the heads, capstan and rollers with long swabs and denatured alcohol. That got things clean. The tape cleaners didn't do well. I am sure there may be better ways to do things now. That is what I did in the 70-90s.
    That is a good idea for a cruise control "On" light.
  3. #5003
    19,983
    Thanks Phil. I dont think it is very compicated to do. Just need to refrence the evtm and I am sure one can snag a switched ground or power and get a light to turn on with cruise on.
    I think that may still be the best way to clean them. I should have thought about all of this while I was bench testing the unit. Now that it is all installed I dont want to remove it...also I have no reason to do so. Just wanted to try the tape cleaner out as I forgot to (didnt even think of) cleaning everything before hand.
    If I am ever forced to pull the cluster I will pursue this. Small green LED that matched my alarm light and low fuel light will do the job nicely.
  4. #5004
    Play me something funky! marquisman's Avatar
    innisfil, ontario, canada
    10,114
    Holy shit... I know I have been away for a bit but damn, your car has had great progress! Very nice! I did the same thing, with going back to a stock cassette deck on GMGT. No need for fancy audio lol.
  5. #5005
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,725
    You still can use the swab and denatured alcohol to clean the parts when the stereo is installed. You will get allot of the dirt. Just have to be more careful and the swab has to be soaked so the lint will not get caught on anything. 5 minute job.
  6. #5006
    40,163
    Have to clean all of the parts though, not just the head. The tape runs across a couple of guide pins, and on the capstan and pinch roller. Crud on the head makes it sound flat and dull, crud on the capstan and pinch roller can cause speed problems. crud on the pins just transfers back to the tape so it spreads through all the rest of the system.
    One of the issues with tapes now at this point in time is they can break down and shed the magnetic material which makes an absolute mess inside. Basically its the same mechanism as sticky steering wheels and other interior panels.
  7. #5007
    19,983
    The tape cleaner I had used contained a cloth type tape and you add a cleaning solution to it. I think the idea is that whatever the tapes cloth touches it cleans or maybe moves the dirt around? Its all voodoo to me. I am just glad a junkyard picked 12 dollar radio worked!...especially one that I never really intended on installing but am now so happy that I did. Thanks for all the tips on cleaning. Certainly handy.
  8. #5008
    40,163
    the cleaner tapes work OK for regular maintenance but when they get really crapped up it requires a little more work. usually that only happens on things that haven't been cleaned in a long time, or if you run a tape that is coming apart. I ended up with a bad tape on my reel to reel and it got brown gummy crap everywhere.
  9. #5009
    19,983
    The tapes degrading and the belts melting are two things you have me worried about....
  10. #5010
    40,163
    the belts are just a thing that has to be dealt with every couple of decades. Not so bad when you change them before they fail, but when it turns to that black sticky goo inside its a real mess to deal with.
    Tapes are hit and miss, certain ones are fine just about forever, others are crap. Ampex tapes especially seem to be bad for whatever reason. Cassettes are newer than the reel tape I have here, most of my stuff is from the mid 60s and mostly still fine. The tape formulas on cassettes are somewhat more stable too, so I wouldn't worry too much about it. Just have a look inside if you start hearing an awful screeching noise to make sure the pinch roller isn't covered in brown gak. If that happens, chuck the tape.
  11. #5011
    19,983
    Been sitting on the ADTR Boxed upper (adjustable) and lower rear control arms since around September..life happened but just got to them today.
    I had purchased and planned to use spherical bushings in the diff ears but I found out Mustang ones are different sizes and just are too small to fit..so Everything stayed poly for the complete quadrabind rear end.
    Everything fit no problem...just a bit tricky to grease the upper arms upper zerk fitting. Otherwise it just plain worked.
    Some pics:
    New and old upper:
    And all installed and greased:
    And the sway bar fits up perfectly:
    They sure are nice and heavy duty feeling.
    Attached Thumbnails Attached Thumbnails IMG_3751.jpg   IMG_3747.jpg   IMG_3746.jpg   IMG_3745.jpg
  12. #5012
    I post a lot... mitymerc's Avatar
    Nov 2005
    2,602
    Cool!, how does it handle now?
  13. #5013
    Jan 2008
    New Jersey
    3,111
    ooo purdy. interested in how it handles now as well!
    Nov 2006
    Dirty Jersey Yo!
    8,297
    Nice! I imagine the ride will change a bit. I know when I had lift bars installed on the Malibu (they were almost the same), it completely changed the ride.
  15. #5015
    19,983
    Quote Originally Posted by mitymerc View Post
    Supper was ready and I covered the car back up and have not drove it since.
    If I notice any difference I hope it is not a negative one.
    Reason I picked them up is to have the ability to adjust the pinion angle (if needed) to subdue the wheel hop I have experienced.
    I have to say my gut and neck are aching today. Havent been under a car like that since the trans install back in late March early April 2020. Its no fun working on the floor. Knee escaped the endeavor unscathed which is something I was worried about so there's a plus.
    Silly me...sitting on these parts for all these months and I could have ordered zerk caps...did it this morning. Will be in shortly to protect the grease fittings on the control arms.
  16. #5016
    19,983
    Popped some grease zerk fitting rubber crap keeperouters onto the new ADTR rear control arms but haven't maneuvered the car out of the backyard to test everything out yet.
    Did manage to put some shine on her...to be honest it was shiny before. I just wanted to polish out some car cover wear marks and put on a nice coat of wax:
    Attached Thumbnails Attached Thumbnails IMG_3766.jpg   IMG_3767.jpg   IMG_3768.jpg   IMG_3769.jpg
  17. #5017
    Dec 2011
    Yonkers NY
    4,282
    A great way to have such a nice day.
  18. #5018
    Jul 2019
    Finland
    701
    Got to say that is by far the best looking brown car I've ever seen.
    Also probably mentioned earlier in this thread, but what wheels are those? HPPs?
    1985 Mercury Grand Marquis LS
    1997 Volvo 850 GLE Estate
  19. #5019
    19,983
    Yessir.
    Thanks.
    Yep. HPPs that I had redone...polished lips, powdercoated centers and clear powder over all.
    http://www.grandmarq.net/vb/showthre...l=1#post800566
    Equipped with factory ford BBS center caps. Have for part number on them!
  20. #5020
    19,983
    Took the car out for the first time since October. It has been in the backyard since then due to personal medical reasons and winter. Also the first ride with the ADTR rear control arms. All seems good so far. I didnt experience any wheel hop yet. I was not going so hard either because it was the first time on the road in 6 months or so. Nothing seems loose and no clanking noises so I say thats a plus.
Tags for this Thread
