Results 1 to 11 of 11
Thread: I have decided to have Vicky's Transmission Rebuilt
    Jan 2007
    Westmont, New Jersey
    9,179
    Default I have decided to have Vicky's Transmission Rebuilt
    Yep, that's right people, Vicky's transmission is basically dead. Luckily there are nearby tranny shops that have good reputations from people I know. So with this overhaul, what do you mangs recommend I have done? I was considering having the flywheel and starter replaced as preventative maintainence since sometimes the starter grinds at start up.
    Vicky
    Currently Undergoing A Skippyville Beauty Makeover! Too Much Stuff To List
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar (Courtesy of Lincolnmania, Gadget73 and SVT98t), Electric Cooling Fan, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, HPP wheels, Working A/C, more mods to come soon!
    Tremont PA.
    15,275
    dont do it there.......take the car to brian!
    GMN Regular 86GmLsCoupe's Avatar
    Apr 2005
    Linden, NJ
    1,103
    Servo upgrade is a start, wide ratio would be nice, I went with Kevlar bands but people have their own opinions on them, and of course a Transgo shift kit.
    1986 Grand Marquis LS 2 Door
    Ext: Medium Shadow Blue Metallic, Int: Midnight Blue, 3.08 open, 235/70/15 Goodyear Aquatread III, Rebuilt AOD w/ Transgo Shift Kit, 3G upgrade from 95 5.0 Mustang, Walker Dual Exhaust w/ H pipe, Viper 5900ST alarm, De-smogged, Rear Civ. Sway Bar, and more.
    24,830
    kevlar has poor friction properties. You're better off with the 2" overdrive band.
    New rear main seal is a good idea.
    And yeah, I'd probably suggest Brian. I've got two of his transmissions and have no complaints. One AOD and one 4L60e (the Chevy). Whenever the trans in the Mark VII eats it, he'll get that job too.
    Fack da Hulk Hogan! Grand Marquis GT's Avatar
    Nov 1982
    Hamilton, AL/Little Rock AFB, AR
    19,463
    Brian.
    Also get a supercoupe converter, works well with LOPOs too! And of course the shift kit, etc...
    Quote Originally Posted by sniper308 View Post
    Everybody have some of crazy the difference is that some have a little less and some have a little more, I have a little less combined with some of eccentric. :heyhey:
    ATT, SNIPER 308. " YOU HAVE TO BE MY EYES " Tomb Raider.
    Quote Originally Posted by DuceAnAHalf View Post
    this.
    if your letting your girlfriend run your life like that, congratulations your a bitch. grab my pocket, i just bought you for two packs of cigarettes.
    My screen name is GREEN, Bitches ! 88grandmarq's Avatar
    North Georgia
    1,961
    Quote Originally Posted by Grand_Marquis_GT View Post
    Brian.
    I have yet to find a listing for a supercoupe torque converter for an AOD.
    find them all day long for an AODE, but NOT the AOD.
    my sources list AOD converters in 2 flavors, low stall and high stall.
    low stall is for 351W trucks and police cars
    high stall is basically everything else, including Mustangs, T-birds, mark 7s, crown vics etc.
    Pirate
    Guest
    I would add a B&M Holeshot non-locking 2400 RPM stall convertor (I'm burned out with the 2-3 shift lugging due to the stock locking convertors), and of course do 4R70W upgrades, such as the 4R70W planetaries, intermediate pressure plate (changes the intermediate clutch count from 3 to 4 discs, and firms up the 1-2 shift), 2" O/D band and reverse clutch drum, and the steel direct clutch shell and drum that allows 6 direct clutch discs....but skip the Kevlar. As stated previously, the basic 2" O/D band, coupled with an 'A' O/D servo ('B' would be fine, also), should be plenty strong for whatever you throw at it. Since the motor is pretty much basically stock, the flash stall speed of the B&M convertor won't be at 2400 rpm, but will help the car accelerate quicker, especially since you won't have a bog when shifting from 2nd to drive.
    I would at least go with a TransGo SK shift kit, with everything set at 'Taxi/Police' along with an H.O. governor weight, or the HP kit with an H.O. governor weight.
    He who shall not be mentioned. mrltd's Avatar
    Jun 2005
    Westminster, MD
    12,851
    What pirate said, except for the non-lockup converter. B&M torquemaster 2400 or 2000...
    Also, if the car isn't HO powered, don't put an HO governor in it.
    Builder/Owner of Badass Panther Wagons.
    http://zombiestig.us
    24,830
    The 2-3 lug sucks, but I'm a fan of fuel economy, so I'll deal with it for the lower heat and lower drivetrain loss presented.
    Mazdas are sort of Ford-ish .... 1987cp's Avatar
    Dec 2006
    Michigan-ish
    5,668
    I thought you got considerably better deals on 2400-stall converters from Scott's connection on eBay?
    Black '81 two-door is FOR SALE! View thread, PM me an offer!
    Black '87 P72 is also FOR SALE! View thread, PM offer!
    New for-sale thread: http://www.grandmarq.net/vb/showthre...ht=#post670339
    Jan 2007
    9,179
    I dropped Vicky off at the transmission shop on Tuesday, I picked her up to day and I must say it's very responsive and the new starter and flywheel really helped! I think the old starter was really tired and drew too much power from the system. The teeth were kind of chewed up on it, I haven't looked at the flywheel yet though. Only cost me $995 for everything, that's a reconditioned torque converter, all the internals replaced, the removal and installation of the transmission. They didn't even charge to put the new starter and flywheel in, and what's good is this shop has rebuilt some AODs in the past, one that I have driven and the car drives really nice.
    Vicky
    Blue
    Mods So Far:
