I bought this thing off a guy with a 1991 5.0 mustang he said it came off. I was trying to sell it to a fox-body enthusiast and he told me its not off a 5.0 mustang at all, and that the cats are in the wrong places. Fit fine on my Lincoln so I don't really know what it could be from other than a Mark VII. Anyone recognize this thing? It looks more like an "A" pipe to me than an "H"
what car is this H-pipe off of?
I bought this thing off a guy with a 1991 5.0 mustang he said it came off. I was trying to sell it to a fox-body enthusiast and he told me its not off a 5.0 mustang at all, and that the cats are in the wrong places. Fit fine on my Lincoln so I don't really know what it could be from other than a Mark VII. Anyone recognize this thing? It looks more like an "A" pipe to me than an "H"1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.Tags: None
looks like a fox catted H to me... the aftermarket catted H pipes have the cats in a different arrangement, maybe thats what the other guy is used to seeing???Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
I just found it here: http://www.performancepartsinc.com/images/oemhpipe.jpg
http://www.performancepartsinc.com/engine.htm
That dudes on crack, it is a stock 5.0 mustang unit for 87-93. And look it costs $1K for a new one!! Jeese he's trying to talk me down from $150 and mine has new cats installed.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
sweet, so I am right, thanks man.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Definitely a Fox H-pipe; the stocker.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
