'95 Bronco XL
    '95 Bronco XL
    Here she is, my first Bronco. Was originally used by the state, for the forest dept. Base model (you know I love 'em). 302 auto, 3.55s, limited slip in back. I think it's a Dana 44 up front and 8.8 out back. Manual hubs, which I like.
    '95 Ford Bronco XL -
    sigpic :rebel:
    Yeps, D44 TTB front, 8.8 Ford rear. The front can use a D50 stub shaft tho, it has a beefier U-joint (the big U-joint between the two TTB arms). I see a new alternator and belts, tires look like they're in nice shape too. So what trans does this have, the E4OD? Let me know if you wanna play with it a bit - I'm pretty happy with my pressure riser and manual converter lockup control, it's like having a 6-spd with a shift kit
      I loved mine. Have fun with the passenger side spark plugs, may have to remove the inner fender. Put some bigger tires on it asap. And if you get rough on it, the hubs always shatter before the axles. I wouldn't worry about beefing anything on the front end but the radius arms.
      1989 Grand Marquis LS
        Fun-looking truck, too bad it's getting rusty.
        Will those bucket seats fit Panthers without lots of cutting and drilling and welding?
          If you change the tracks they might. Mounts are totally different. I still got my set. They are rather tall though.
            not to bad jeremy have fun with it
              I guess it's a E4OD...button on the end of the shifter. It's hard as hell to get the 4wd shifter back...what can I do bout that?
              sigpic :rebel:
                It's a Bronco, they're rusty from the factory.
                  i always liked broncos, but never understood why them and the blazer/jimmy all rot in the rear section. we gots a 87 jimmy 4X4 at work i want for a off road beater...nice toy btw.
                    Nice truck, have fun!
                    1991 Mercury Grand Marquis LS - Current - June 2016 POTM Winner
                    1996 Mercury Grand Marquis LS - SOLD
                    1991 Mercury Grand Marquis LS - SOLD
                    1987 Mercury Grand Marquis LS 2dr - Long gone
                      Yeps, OD cancel button is an E4OD thing. As for t-case shifter being hard to move, mine would do it too sometimes, I'd just get the truck driving and under 5mph shift in and out of 4 high.
                        its not a base model if it aint a stick shift
                          My brother had an '87 (351/C6?) that he spent a ton of money on. When he was done it was nice. It was awesome for plowing snow/ winter driving.
                          I wouldn't mind having one. Aside from a Suburban, I think they are pretty much the ideal SUV.
                          Good luck with it.
                            Mine only had rust on the tailgate. And those shifters are all a pain in the ass. The older chevies would pop out unless you held your foot on it.
                              I thought Chevies use the NP208, whereas this has a BW13xx t-case?
