Results 1 to 9 of 9
Thread: Dying Head Gasket?
    Nov 2006
    Dirty Jersey Yo!
    8,660
    Question Dying Head Gasket?
    Lately I have been seeing water on the dipstick and a little frothy stuff on the oil fill cap. The water freezes on the dipstick and melts to the touch. I had this problem in the summer and after I changed the valve cover gaskets, it went away. The 5.0L runs smooth though and doesn't smoke or anything. At first I thought that it might be sucking water through the stripped oil drain plug (it leaks pretty good) on the front sump of the oil pan. After I thought about it, I realized that there couldn't be enough vacuum to do that. The only thing I can think of water getting into the oil is through the head gasket. Do you think the head gasket is on its way out?
    Jim & Marita 87_crown_vic's Avatar
    Apr 2006
    Omaha, NE
    2,661
    ummm... ever think or see any issues with the lower intake? usually they wil go out and head gaskets dont blow often on these cars that i am aware of
    Addicted to 86-87 Panthers
    There's no welders in Heaven, they all went down to hell
    Apr 2005
    Chesterland, Ohio
    3,182
    only way to know is drain the oil. If its dark brown/black you're fine, if it looks like a chocolate milkshake then your gaskets are smoked.
    Condensation usually builds up in colder weather and causes a frothy look to the fill cap and dip stick, its normal. Dont be worried. If your motor isnt smoking or running odd and your oil doesnt look like a frothy mess when you drain it your fine.
    Birdsboro PA.
    17,879
    if theres a good amount of water in the oil then maybe.......damm near impossible to blow a 302 head gasket unless you get the engine so hot that you blow the head gasket....when was the pcv system last checked and the screen changed?
    Proud to be a GMN Member Brandon's Avatar
    Aug 2008
    North Carolina
    1,425
    You haven't put any chrome Valve covers on it have you. I had a set on my old 84 and it drew Condensation in the winter.
    41,571
    If the engine isn't fully warming up to cook off the condensation, that will do it. I get a bit of white goo on the dipstick for my truck for that reason, I work 3/4 of a mile from home so the motor doesn't warm up.
    Apr 2006
    Omaha, NE
    2,661
    you work 3/4 of a mile from home??? i thought you worked from home. any rate...
    cold weather is big contributor to short distance driving finding that crap on dipstick and oil cap when vehicle isnt warmed up enough from long enough drives. if you are still concerned and coolant is low and no leaks visible, might think about possible intake leak.
    Nov 2006
    Dirty Jersey Yo!
    8,660
    Nah, I couldn't change the PCV screen screen because it was jammed in the intake really good; even a drywall screw, vice grips, and my father pulling on it wouldn't get it to budge. I did change the rest of the PCV system during the summer when I did the valve cover gaskets. No chrome valve covers either, I couldn't get the Ford Racing EFI covers to work with the lopo intake. It probably isn't warming up enough. It's been unseasonably cold here for quite a while now. I guess it ain't a big deal since the car runs good. Plus I got other problems with non-Ford vehicles to deal with.
    41,571
    Quote Originally Posted by 87_crown_vic View Post
    New job, I have to commute now
Tags for this Thread
