Results 1 to 20 of 20
Thread: HELP - 03 GM can't get rear rotor off!!!
    Question HELP - 03 GM can't get rear rotor off!!!
    Hello,
    My GM's rear rotors failed inspection today. I got new rotors and I am having a hell of a time getting them changed. I removed the brake caliper, the emergency brake is NOT on, and I can't get the rotor off. I removed the rotor clips, and everywhere that I have read...it says the rotor should come off. I have sprayed with PB blast, I have banged the hell out of it with a mallet, etc.
    Any suggestions? When I bang on the old rotor...where should I be hitting it. on the sides?
    frustrated in pa!!!! I am ready to take my sledge hammer to the car right now.
    I'm in the Plain Wrapper rolling in the hammer lane!
    Mazdas are sort of Ford-ish .... 1987cp's Avatar
    Dec 2006
    Michigan-ish
    5,668
    Dang, I had no idea your state safety inspections extended to brakes as well! I could so not afford to own a car if I lived there.
    Random thought, have you tried a three-jaw puller? I've had success with that on drum brakes that absolutely refused to come off despite any amount of PB Blaster, heat cycling with a torch, and whacking around the rim with various hammers.
    Black '81 two-door is FOR SALE! View thread, PM me an offer!
    Black '87 P72 is also FOR SALE! View thread, PM offer!
    New for-sale thread: http://www.grandmarq.net/vb/showthre...ht=#post670339
    Quote Originally Posted by 1987cp View Post
    Took it to a Tires Plus...they had to find something. Anyway, not sure what a 3 jaw puller is but I will try anything at this point. Thanks for the advice.
    Dec 2006
    Michigan-ish
    5,668
    Here's a representative 3-piece set from Harbor Freight, albeit too small for pulling brake rotors. I frequently rent stuff like this from my local AutoZone, as it's free. Their 10" model was what got me out of trouble before.
    http://www.harborfreight.com/cpi/cta...temnumber=8832
    Fort Wayne IN
    5,307
    The parking brakes can be a real bitch. Sometimes you just have to pound to get it off.
    in the woods
    2,830
    Maybe back off the adjuster on the parking brake. Instead of using a mallet use a real too. Rotors are junk anyway. 4 lb mini sledge works good.
    1989 Grand Marquis LS
    And thats just about the finest smell in the world 82LTDQS's Avatar
    Aug 2007
    Florida
    533
    Im thinking parking brake.
    Vehicle: 1965 Pontiac Catalina (fastback 2+2)
    Chasis: 1982 Ford LTD Country Squire
    Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
    Big Brake swap and front suspension completed.
    Hello Again! Thanks to everyone who responded. After a about an hour on each rotor, I was able to get them off. I kept spraying with PB blast and hammered and hammered! There's the shield on the inside of the rotor so you only have a 2 inch space to hammer. I put the car in neutral and then could whack it, turn it a little, whack it again, etc. I probably made the job 10 times more difficult than it had to be...guess that's what happens when frustration sets in.
    Happy top-notch mechanic in Harrisburg, PA.
    central VA
    11,978
    Ha, your proximity would have made the easiest solution to go see scottmang, a master guru who just happens to live near you... if you didnt know.
    24,837
    PA state inspection does require a very comprehensive check of the vehicle, including measuring rotor thickness, ball joint play, and other stuff. Honestly its not a bad thing, for the $75 it costs you end up with a car you know is safe for yourself and other people on the road. Of course, there are places that will slap stickers on, but since there is a lot of potential coin to be made off inspection items, shops like to do them.
    Tremont PA.
    15,275
    got it dale good!
    sometimes you gotta use a bigger hammer
    Dec 2006
    Michigan-ish
    5,668
    Dang ... you mean you have to PAY for the inspection so they can tell you your junk isn't up to snuff? I would have assumed that being required by the state, the testing would be done at state expense, just like emissions testing in NW Indiana.
    Member Lonnie's Avatar
    Feb 2009
    Youngstown,Ohio
    131
    Sadly no. In PA the customer pays for the state inspection and depending on which county they are in an emissions test as well. The shop I work in is in an emissions county and we charge about $47 for both.
    As for the rear rotors the adjusters would be the first thing to back off, and the pivots for the parking brakes tend to rust solid in the rust belt so it would be worthwhile to free them up to.
    Current stable:
    1984 Ford LTD Crown Vic
    1994 GMC Jimmy 4x4
    1972 Volkswagen Camper Bus
    2000 Ford Windstar
    Fat 'N Bald..... O's Fan Rich's Avatar
    Mar 2008
    Reading, PA
    11
    This is why you should be in the habit of using your parking brakes.
    Helps keep things working and makes things a bit more secure!
    2003 Mercury Marauder
    Trilogy #132 Posi Performance Ported
    461rwhp 449tq
    And Lots of other Mods
    Aug 2007
    Florida
    533
    In FL, they dont care. No emissions or inspections. I wounder what they would say about my car if we did have inspections?????
    I love it when a plan comes together CheeseSteakJim's Avatar
    May 2006
    West Granby, CT
    3,023
    I would've never even seen my truck if this state had safety inspections.
    Dec 2006
    Michigan-ish
    5,668
    Quote Originally Posted by 82LTDQS View Post
    Hard to tell. I know my wagon would definitely not be being driven right now, and they'd probably find something major wrong with the P72 as well even if they didn't test for emissions. I guess like I've said before, what bugs me worst about state inspections of any sort is that they force older vehicles off the road when people can't afford to make the repairs and/or give people unnecessary incentive to go into excessive debt on a brand-new car.
    Panther Lifer 89merk's Avatar
    Oct 2008
    MIAMI,FL
    669
    Why did they eliminate inspections in FL? i remeber as a kid my parents taking their cars to get inspected and they only checked emissions not the detailed check PA does. thats crazy.
    4thPanther..03 MGM LS
    previous panthers: 87 MGM, 85 CV 2 DOOR, 89 MGM.
    in the woods
    2,830
    Not sure. I'm fairly certain my car would pass though. Unless they check for oil leaks.
    Dec 2006
    Michigan-ish
    5,668
    Quote Originally Posted by 89merk View Post
    That's the exact same thing I grew up with in Lake County, Indiana. I remember one summer it was incredibly hot and the line at the smog-check station was amazingly long, probably stretched around the block - and I had to sit in that line not only with my mom in her car, but also with her in a family friend's car that she took to get tested! That alone taught me that smog testing is evil.
    In '96 my Quad-4 Cutlass Calais flunked emissions in the rev-to-2-grand-and-hold-it-there test and needed a new oxygen sensor or something (don't know what, wasn't allowed to work on it much), and in '97 the Colony Park passed the chassis dyno test just great on the first try. Then I left that corner of the state and haven't had to worry about emissions checks since.
